Hi 🙂
I am ordering some components from Reichelt and when I was searching for FR207 i got this as result Security Check
FR207 = FR207G = BYV96
= Not identical with BYV 96E
Can I use byv96 as replacement, if not what is correct replacement for FR207, thanks.
I need 8 pcs, 4 for lm317 power supply and 4 for jlh headamp kit.
This is the recommended replacement according to Farnell;
https://uk.farnell.com/multicomp-pro/fr207/rectifier-single-2a-1kv-do-204ac/dp/2675057
it is a 1kv 2A normal recovery diode. Nothing too special.
If you need that high voltage/current parameter all of them are in the same ballpark the BYV part is the faster switching for SMPS/converter applications, if you are using them as low volt rectifier parts its like running a Corvette in a disney land parklot
The power supply has a lot of capacitance? High voltage rectifiers don't get a long with high current pulses
The FR series are fast recovery diodes. Hence the FR on the number.
The BYV96 series are also fast recovery, but while the BYV96E is a 1000v part, it is only rated 1.5A, while the FR207 is a 2A part.
To replace the FR207, look for a fast recovery 1000v 2A part. Which includes FR207.
Jon's link says standard recovery, but the data sheet from Farnell says fast recovery.
Agreed FR is Fast Recovery
https://www.mouser.com/datasheet/2/395/FR201-231688.pdf
HER208 comes to mind ...
http://malibor.by/sitedocs/12194.pdf
100pcs HER208 2A 1000V ultrafast recovery diode | eBay
I've dealt with Shengming several times without issue so if you can wait and need a bunch, they are an option. My go to Chinese supplier.
HER is ultrafast and has larger voltage drop than fast FR.
I would better use some Shottky for 20V 0.5A.
Yes, they are very close.Can I use byv96 as replacement, if not what is correct replacement for FR207, thanks.
True... I didn't really think a 0.4V difference on a 1000V part was a big deal...
Here's FR207 from Shengming.
20PCS FR207 2A 1000V Fast recovery diodes | eBay
For what it's worth, I use FR607 in my monobloc amps for the diodes in the voltage doubler PSU.
- Design & Build
- Parts
- Help with FR207 diode.
