Hi! I built my first subwoofer and wanted to share the story with you guys for feedback and just for the lolz.
This is a 12" walmart sub for $30 put into a sealed enclosure made out of the top half of a vintage JVC floorstander.
Here's the write up, with pictures:
Hold my beer: walmart subwoofer build - Google Docs
Enjoy! and I'm excited to be a part of the community.
Looks like a fun build. 🙂
I would maybe try to notch out the tree peaks centered around ~47, ~56 and ~67hz as well.
Did you try with a sharper 48db/oct LR or BW lp filter a little bit higher up?
You built two subs?
Have you checked measurements between channels? Sometimes one will have a peak where the other has a dip in-room.
You built two subs?
It was fun! Those peaks are likely due to room modes and mic's position in the room, since my bookshelf speaker had the same curve shape around those frequencies. I hesistate to try to correct those too much because it could inappropriately lessen the output in some other listening position.
I only built one so far. Maybe I'll build a second one but if I do I think I'd go with a different design or woofer. Also chopping a speaker box in half so that the edges are all completely flush was a major PITA that I'm hesitant to repeat unless for a really good cause.
I have a spare walmart woofer, I'm thinking of just returning it as I want more low frequency extension and I feel these woofers wont do it for me, with an Fs of 37Hz. But I'm a noob so maybe I'm wrong. What do you think?
