HOLMImpulse: Measuring Frequency & Impulse Response
I have a new audio interface (Audient iD24), where the optical outputs I want to send audio to for measurements are ASIO channels 9 and 10. I love Holm Impulse but it only supports the 4 first ASIO inputs/outputs and I really need to use 9-10 out. Optical in is 3-4 so it's no problem. Do you guys/gals know of a workaround that can have Holm send output to ASIO out 9-10?
diyAudio Moderator
Joined 2008
I've pulled these from the Wayback Machine, ca 2021.
  • HOLMImpulse-1.4.2.0.msi.zip
  • HOLMImpulse-1.4.2.0-x64.msi.zip
Reactions: 1 user
