How can I filter out an inverter for less noises
Tahmid said:
Hi Gaetan,
One more query:
I see 2 transformers. Can you please tell me how they are used? Series input? Series output? Parallel input? Parallel output?
Thanks.
Hello
Sorry for late reply but there was urgent repairs to do on my house.
I did take the double sides pcb out and I've seen that it is much difficult to figure out since there is kind of parallel wires mix with serials one, and there is others traces that I can't see who go between the pcb and the transfos and there is also some kind of sensor into the windings of the transfos.
So I will forget to change or double the transfos.
Thank a lot for trying to figure out the transfos types and winding.
Bye
Gaetan
zigzagflux said:
That's what I am currently doing; using a lookup table for a clean sine wave. However, I am feeding into a DAC and then to a class G amplifier. Amplifier feeds a 48:120V step up transformer.
Designing your own bridge that runs reliably and has controlled EMI/RFI is not a small task, certainly not one gaetan sounds keen on pursuing. For simplicity, reliability, and cost, I see no better way than ferroresonance.
Funny thing, gaetan, is that one of those offered free shipping. Maybe not to Canada, not sure. But I doubt you will find a better way that can be implemented DIY in the next year. If your time is free, you can certainly pursue PWM type methods and learn a lot in the process.
Hello
Not free shipping to canada and our money are now lower than US money.
I did find some kind of big diy PWM inverter on the Net, I will post the link wen I will have look a bit at it.
Thank
Bye
Gaetan
Hello
Here is a diy 2kw PWM true sine inverter I've found on the Net, it would need less filtering to clean the noises.
The only problem for me are the PIC16C84 MCU , I dont have any experiences or knowledges about those PIC and no hardware to program it.
I can see on this web page that he is using two ferroresonant transfos in parallel, that's ok since I have some big transfos here at home.
Here's the link;
http://www.technology.niagarac.on.ca/people/mcsele/i2k.htm
Anybody did seen or built that 2kw PWM sine wave inverter, any ideas or comments ?
Thank
Bye
Gaetan
WHOA !!!
DO NOT MODIFY THE INVERTER !!!! It has been designed to operate properly as it is. If you "double" the power transistors then you will be doubling the load of the signals that drive those transistors. This will most likely overload them and the results will be worse than it is unmodified.
Trying to change the inverter's output is pointless. Inverters work by generating a 60 Hz square wave to approximate a 60 Hz sine wave. There is nothing you can do to make it more "sine-like".
WHY do you want to get a cleaner (more sine wave-like) output ??? If inverter noise is getting into your audio (analog) circuitry then you need to do one or more of the following:
1) Shield the audio circuitry;
2) Shield the audio signals going into and coming out of the audio circuitry;
3) Properly filter or regenerate the DC power supply voltages powering the audio circuitry;
gaetan8888 said:
Hello
I will not modified the inverter, but it have mosfets output, so it is much less load to signals that drive those transistors.
Have you take a look at the link for a diy 2kw PWM true sine inverter I've found on the Net ?
Any ideas about it ?
Thank
Bye
Gaetan
That inverter design is very similar to that found in some APC UPSes. The PIC drives two MOSFETs through a discrete driver circuit which drives a 60Hz transformer. A simple resistive voltage divider is used for voltage regulation. It is a partially bidirectional design. In normal operation, the transformer is connected to the input through a relay. The MOSFETs stay off in that mode and the circuit reconfigures into a charger. That design works nicely as long as you don't mind the weight.
Many modern inverters including the one you have step up the voltage at a higher frequency and generate a 60Hz wave with a H bridge.
Hello
I would use my T-MOS mosfet, MTE215N10E or MTP60N06HD
I have few big transformers that I can use there. I presume that the guy use two transformers in parallel because he allready have them.
Thank
Gaetan
gaetan8888 said:
Hello
A true-sinewave inverter cost too much for me. So I have a Xantrex XPower 1000 inverter.
This 1000 watt inverter do have a modified sinewave output.
Is it possible to filter the output voltage to bring it closer to a sine wave signal and have much less noise ?
And I did buy mosfets and diodes to double them in parallel on the inverter board, I will use a bigger heat-sink, so it may go a bit more than the 1000 watt, but I can not find any number on the two transformers.
Anybody would know what type of transformers it can be ?
I include photos of the insides of my Xantrex inverter, with some parts numbers on the first photo.
BTW, Xantrex do not reply to any parts request or technical question.
Thank
Bye
Gaetan
Hi gaetan8888,
can u tell me the temperature of the two transformer at full 1000W load. Is it very very hot as the low side carry huge current (90amp!).....?
gaetan8888 said:
Hello roomi
Yes the transfo get hot but not too hot and there is a fan to cool it.
Btw, have you look at the diy 2kw PWM true sine inverter I've found on the Net; http://www.technology.niagarac.on.ca/people/mcsele/i2k.htm
Do you know about PIC16C84 MCU programing, I dont have any experiences or knowledges or hardwares for PIC.
Thank
Bye
Gaetan
actually, i have built a dc-dc converter (12vdc-350vdc) for making sine wave inverter. during load test at 350v dc the primary current (push-pull) was measured 33A and the transformer was very hot (abt 72degree celcius). I am worried abt what will happen when it takes full load current of 60 amp..!!!
my trnasformer is (3T+3T)/124T and i am using push-pull topology at 43Khz..... each primary winding consists of 7x21swg cu wire and secondary is of 1x21swg cu wire......
I don't have much pic experience. but u can find tons of inf on net for pic16f84.... but i do have some bascom avr experience........
Are you using a single conductor primary or a multiple conductor primary? Consider the AC skin effect of using a single large diameter conductor versus using mulitple smaller conductors to reduce copper losses. Litz wire is an option, but I perfer to using multiple conductors laid flat to avoid uneven winding with round bundles of conductors with a large diameter. Interleaving primary and secondary layers also helps a bit. A well laid out transformer will reduce inductance leakages which means small snubbers.
Also check for possible core saturation or near core saturation. Try adjusting the switching speed higher with an static output load to see if your running too near the point of core saturation. Plot out the current vs frequency using a static load to determine the optimum frequency for a given load. Consider that no core material has a perfectly square B-H loop.
One option if you use a microcontroller as a controller is to alter the switching speed as the load increases to avoid running to saturation issues. To make the design simpler, you can use several discrete frequencies instead of trying to develop a complex function that completely dynamically adjusts the frequency. ie for 0-250 Watts 43Khz, 251-500 48 Khz, 500-750 56 Khz, and so on). Using a Current sensor and an ADC input, you can adjust the switching speed to the appropriate frequency. You want to use low switching speeds at low loads to reduce switching losses, and higher switching speeds at high loads to reduce copper losses caused by near core saturation.
About the mcsele/i2k.htm diy 2kw PWM true sine inverter I've found on the Net.
I am not sure anymore it is a true sine wave generator:
From the i2k web page:
The output wave begins to resemble a square wave once again. The scaling technique is simple, but not optimal (still, it should produce an output considerably better than the simple squarewave currently used).
I am french speaking so sometime I have a bit difficulty to fully understand a english text.
By reading slowly his text, it is not very clear if it is a real sine output but it is seem to be a kind of modify sine, unfortunately the guy do not show the ouput signal on a oscilloscope.
If it is not a real sine, I will not build it.
Thank
Bye
Gaetan
Hi TechGuy,
a lot of thnks for valuable technique u described.........
i am using 7 number of wire of 21 swg together to make 3T + 3T as primary and a single 21 swg wire to make 124T as secondary (i am using push-pull topology).
i am confused whether the turn and size of wire selection of my transformer is right or not. i don't know the step by step method for building 45 khz switching transfrmr for inverter design. please help me in this regards............:bawling:
Gaetan
by looking at the ASM and read the web link carefully my UNDERSTANDING about the I2K is, its a PWM sine wave , its close to a so called true sine wave but the harmonic content is a bit high then true sine wave inverter found in marketplace, I2K is designed for motor stuff and i guess motor dont mind some harmonics, there is lot of room for improvement like use a faster PIC with hardware PWM and there is alternative solution as well dont need to hack ASM and PIC stuff,
http://www.s4wsbox.com/?q=node/31
what type of core you are using, have you measure the cross section of the core,
Hello
Reading this text, I was not sure it is a true sine wave generator:
And for the inverter from the link, http://www.s4wsbox.com/?q=node/31 , it need 10x 12 volts batteries in serial, since it do not use an output transformer.
Thank
Gaetan
I don't understand the type of core (i don't know what is ETD, ETD49, etc...Please help me in this regrads, I am newer in power elec.). The core area is 1.74 sq c.m.
That seems too small of a core for 45 khz @ 33A. Its probably saturating. If the core is a ferrite, you can probably drive it at a much higher frequency to avoid saturation. But the small core size will limit its maximum output (a guess about 750 Watts, but I could be wrong).
The issue I see is that its using fixed output inductors (200uh*2) which will limit its output power to about 250 Watts. The advantage of using an output transformer is that it has variable inductance based upon the output load. There are some other issues too. This looks more like a Modified squarewave inverter using a pair of output inductors and a cap to smooth out the square edges. It you put any load on it, the output waveform will become greatly distorted. It looks like the oscillation is running at 120 hz, and is using a 555 Timer to integrate the triangle wave into a squarewave that averages out to sinewave output.
Its not really true PWM sine wave controller. In a true-sine or pure-sine the switching frequency is much higher than 60 hz. A PWM sinewave output should look like this:
gaetan8888 said:
Hello
Thank
Bye
Gaetan
i can see there are 2 trnsfrmrs for delivering 1000W. my question is how can they share load equally (I guess they r connected in parallel after the rectifier) ? because it is not possible to be 2 transfrmrs of exactly same in all respect.
