How to block high frequencies from getting to a woofer
Ah, they might be pretty good for experimenting with, having come from an organ. No, you won't get any bass in free air but don't worry. Now, don't laugh but my first play with OB was a couple of 6" coaxial car speakers 'mounted' in a couple of huge sheets of cardboard, almost a wall actually, I was amazed at the result and that set me off......
Yes, the H-frame will help. Even as efficient as it is, the woofer is going to loose a lot on open baffle. Losses in the bass can be as much as 10dB, sometimes more. The H-baffle may not be that bad, but you can't beat physics.
I don't quite know what to expect. However, I'm being realistic that it won't be close to the Polk 12" 505 powered sub I run currently. But a significant step up from the 8" full ranger's bass output is what I'm hoping to get.
Ok, just been off to have a quick look at polk subwoofers, not familiar with them but at first glance looks like generic sub. It will have it's own crossover and amplifier, there might be an auxiliary output but I don't know, do you? Can you give me model No.? What I'm saying is we might be able to use that to give you a quick and simple comparison
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033226.pdf
That's the link to the Polk PSW505 sub that I have.
Just so you know, I have a vintage quadraphonic 4-channel receiver that is my main.
Had a look at manual. The only way to do what I was thinking is to remove the speaker drive unit from the sub and connect the wires that went to it to your 15in unit instead. How do you feel about that?
I may have already done that... just daisy-chained it off one of the 8" full rangers. I know that might be a no-no cuz I think it dropped the ohmage to about 4 ohms the receiver was seeing. No problems though. But the 15" sounded good... just not much bass from such a large speaker.
Your woofer in an H-frame with a single coil in series will certainly add bass to your 8" fullrange. Enough bass? I don't know.
I've built a few OB speakers with a 6.5" or 8" or oval fullrange as the main driver. Adding a 15" or a couple of 12" under that works well. The medium size fullrage drivers rarely play as low as you'd like on OB. They tend to die off in the 200-300Hz range. The woofer will pick up a lot of that slack.
If your organ woofer on the H-Frame does not have enough bass to match the 8" FR, there are several things you can do to fix that.
  • Get more woofers
  • Use different woofers
  • Use a plate amp, or similar, to go active on the woofer
  • Attenuate the 8" FR to match the woofer. A single series resistor would work, or an L-Pad
Experiment with the series coil in the woofer first, then we'll know where you stand.
I rarely bother with crossovers for my subs etc and it sounds fine.
I put a capacitor in series with the tweeters though.
+1 A sub will just naturally attenuate high frequencies .
If you're running it Open Back, then you will get cancellation of lower frequencies, which is somewhat of a waste. I would personally put it into a closed cab, possibly ported, or even a folded horn.
Sent from my phone with Tapatalk. Please excuse any typpos.
