how does one measure these with an oscilloscope??
I am playing with a horn design but would like to measure these against frequency response and waterfall plots.
computer software free🙄 or buy oscilloscope if so how do i 😕do it
PC, built in sound chipset or soundcard and interface hardware (protection, amplification/attenuation) and software do most everything better than a 'scope for loudspeaker measurement frequencies
A scope measures time so you would have to convert time to frequency.
Time=1/Frequency.
Having said that you can sweep your signal generator and watch the waveform increase and decrease on the scope. The sig gen will have frequencies marked on it.
Time=1/Frequency.
Hey Charlie!
Commercial tools include OmniMic and Clio.
Free include Room EQ Wizard.
Why don't you start with REW first?
Best,
E
Best,
E
For electronics get a scope ( they work at much higher freqs. To see instability), for speaker testing a sound card is much better, the software does a lot more ( freq. plots, thd , waterfalls etc. ) and it will also generate test signals.
Also, a goood book to get you started in measurements, is Testing Loudspeakers by D'Appolito.
http://amzn.to/2lAGmuH
Best,
E
Best,
E
Sorry been a bit vague in my question.
I have REW. Berihnger mic etc and using laptop for general measuring but looking into trying to see the wave exiting the horn? If this is possible
I have seen pics of oscilloscope displays attached to certain speaker builds Danley, XRK build? Small syns, or bwaslow i think regards square wave
In other words do you simply connect a mic up to an oscilloscope and plonk a frequency through the driver?
Get a software oscilloscope. Hook up your mic to your sound card. Choose that sound card inlet as Ch1 on your oscilloscope. Feed your speaker suitable signal; triangle, square etc.
The question would be - what do you think you'll see with the mic feeding the oscilloscope vs software on the PC?
- how to measure sine/square/saw triangle waves oscilloscope
