Alternatively - does anyone know any way to fill a mashed up hole so a screw can be driven tightly into the hole once more?
Whittle a tapered plug from pine. (like a large toothpick)
Dip in glue and drive in tight. In this case you can insert it from behind, and cut flush.
Good idea, I know 'em but hoped I could use somewhere local, and its only large quantities at Screwfix. I looked and I can't find threaded inserts anyway, bah, for a company with screw in the name they don't have a wide range of screw-based products!TeePee said:Try www.screwfix.co.uk, much cheaper than B&Q!
Sounds interesting, but I'd need to widen my holes with a drill first. Certainly another possibility.x. onasis said:
...here's a thought - use fresh holes, but this time look for a screw specifically designed not to strip MDF! If such a beastly screw exists!
Thanks for considering my problem with me 🙂
Vikash said:T-nuts alone are not enough IMO. There's always one that will pop outLuckily I've yet to seal the final panel.
Why would T-nuts come loose? After you turn a bolt into it, it tightens itself (pulls it into the wood)? You do have to be carefull that while tightening the bolt, that the teeth of the nut don't come lose (turning around in the MDF).
I have to admit that I applied a lot of woodglue around (and on top of them) just to get a bit of extra security.
reply
Yer T nuts with pozi head bolts is the standard for holding pa speakers in cabs.
Extremely heavy drivers like pa 15 or 18 inchers with 120 oz+ magnets tend to use large bolts and medium washers, and large non-swivel nuts to hold them in place.U need a wrench and spanner for those type.
This is a bit off topic but my 12" driver has the center part wrinkled to the inside. One of my nephews has found a way to pull it. The center material is kind of a plastic membrane with some cloth over it (I think). How can I put it back in the right way? I though about using a vacuum cleaner, but that's a bit risky...
Miguel
Miguel
Hi Miguel,miguel2 said:This is a bit off topic but my 12" driver has the center part wrinkled to the inside. One of my nephews has found a way to pull it. The center material is kind of a plastic membrane with some cloth over it (I think). How can I put it back in the right way? I though about using a vacuum cleaner, but that's a bit risky...
Miguel
If its a coated paper or pp cone it's probably ok to use a vacuum cleaner to pull it back - I presume you're talking about the dust cap here? If it ruins it I'm sure it'll still knock out the tunes ok, hehe. 😀
No not wood, steel or something simular would be my choise.SimontY said:
Just to clarify: I attach a small piece of wood to the inside of the baffle, and screw thru the baffle into that, maybe even using a t-nut there?
With a M5 thread for driver screw.
The cone is paper but the center part is made of a more rigid material. I dont know this is called the dust cap... Its the center circular portion that has an arc in opposition to the cone.
Miguel
Miguel
Ahh, I see now. I guess you need to have a metal workshop then! There goes that idea for me...Keld said:
That is the dustcap.miguel2 said:The cone is paper but the center part is made of a more rigid material. I dont know this is called the dust cap... Its the center circular portion that has an arc in opposition to the cone.
Miguel
I saw someone mention propel nuts from the UK. I believe they are the same thing as hurricane nuts here in the US and can be bought cheaply from Parts Express.
I have not tried to insert a normal T-nut into MDF but got the impression that that would be difficult to hammer in and would have a chance to mess up your perfect Jasper Jig cut baffle. So the hurricane nuts are perfect for MDF for me. I use a machine screw plus machine washer to pull the nuts into the proper sized hole.
Here:
http://www.partsexpress.com/webpage...DID=7&CATID=41&ObjectGroup_ID=259&filter=nuts
Here:
My final suggestion is to try what I'm about to; Use threaded inserts. I don't have these yet so can't say for sure, but you may be able to insert them into your existing mashed holes and the thread on the inside will allow you to bolt into it.
Simon,
I got the inserts from BK and they were perfect. They have a small base and a grip that looks similar to wall plugs, and are much better than the T-nuts they replaced. Because of how they grip into the wood one-way, they may even be ok to use on the front of the baffle (if access to the rear is too difficult). They went in to my existing holes (churned up by the T-nuts) really well
T-nuts, pah!, never again!
Yesterday I cut the hole for the driver but it came out about 1 cm too large😡
I am thinking of opening the hole more, to have a larger diameter than the driver, and glueing a second piece of MDF behind the hole, covering a large area (much more than the hole) and then cut a new one that fits! Any other suggestions that could work? If I put the driver against one side of the hole now, the screws holes of the driver on the other side can't be attached.
Miguel
Miguel
Excellent news! But where are they on the BK electronics website? I can't find them :-( Do they come with matxhing bolts?Vikash said:
Simon,
Cheers!
Heh, ok, call or e-mail it will be!Vikash said:You won't find such delicacies on their website. Best to give them a call. I got gold plated allen headed bolts with them, but I'll use them when I want a nicer finish on another project and just use standard m4 bolts for now.
Those gold plated bolts: wow! They would/will look super-cool when I get round to painting my speakers shiny black!
You reckon I'll get away with forcing them into a hole, from the inside of the baffle, which is rounded? M4 sounds like my required size...
Why can't you (anyone) use machine screws with regular nuts and use epoxy (two part was what I was thinking) to exopy the nuts in place on the back of the baffle? Flush with the back baffle or recessed into the back baffle to put in another way to add strength (it would stop the nuts from possibly twisting off add allow you to use much more epoxy and add surface area) would be a good idea. While the epoxy is drying you should screw the screws in to make sure that the nuts are in right position for the screws to screw into once the baffle is mounted on the front of the speaker.
This seems much easier than looking for the right kind of specialty nut. I think I will try this probably.
SimonY,
The best, easiest and strongest fix would be to glue some pieces of wood to the inside of the baffle where each screw hole is. Then use t-nuts or whatever to attach the driver securely this time.
SimontY said:...here's a thought - use fresh holes, but this time look for a screw specifically designed not to strip MDF! If such a beastly screw exists!
Screwfix sell "MDF Screws".
http://www.screwfix.com/app/sfd/cat/cat.jsp?cId=101705&ts=19972
Nice to see this thread revived! Actually I still have the screw problem, so I appreciate these suggestions. (not got round to sorting this yet, been doing other hi-fi type things!)
Jimmy154 - I don't have any epoxy, but otherwise this aint a bad idea.
johninCR - I will probably try fixing in some bits of wood, but it's gonna be very tough, as the inside is chamfered, so there may not be anywhere to fit the bits, at least for 2 edges.
Matttcattt - I've seen Screwfix's MDF screws, but they don't look all that different from other screws, and they are countersunk, which is asking for trouble. Flat would be more apt.
- Subwoofers
- How to mount a driver in a subwoofer
