How to wire XLR inputs into my tube preamplifier
You will have to change your preamp input stage from single ended input to balanced input.
But then, you either have to change all the other preamp circuitry to balanced, or change the balanced preamp input circuitry back again to single ended for the next preamp stage.
Or, if you make the whole preamp balanced from input to output, you will have to change your power amps input to be balanced input, etc.
Many Balanced XLR outputs are not only balanced, they are referenced to ground. + to ground, and - to ground.
If that is the case with your new DAC, you can wire the + output of the balanced XLR and the Ground output of the XLR to the orignal input of your preamp (without any modifications to your preamp). All you need is the XLR connector that fits into your DAC output, a shielded cable, and a RCA Phono Plug.
That is the simplest solution.
And it gets you up and running until you figure out if you want to make major changes to your preamp (and potentially your power amp).
Transformers are the way to go from "balanced" (XLR) to "single ended" (RCA). Transformer laminations = weight and weight = shipping expense. The OP is in New Mexico and so (fortunately) is Edcor.
djn, talk to Edcor about acquiring a pair of line level transformers that safely and efficiently make the "balanced" to "single ended" transition.
True, but it would also cost many times as much.
I'm also using one as the interstage for a 12AU7 in a guitar preamp. It's not parafeed, either.
I have a pair to use as input transformers but I haven't built that project yet.
Yeah, $250 each is a lot, but those are for a more specific purpose that you don't need. A pair of the Altecs should be right around $100. You can grab a couple of octal relay sockets to try them out, and if you don't like the XLR out as much as the unbalanced output (which is a completely reasonable outcome), you can just resell the Altecs and recoup your cost.
Transformer balanced inputs are great, but only if the transformer in question is good quality. Good line transformers are expensive, and I would much, much rather see an op-amp circuit than a low-quality transformer. At about $6 I am highly skeptical of that Triad model.
I have not used the Edcor models, so I cannot comment on their performance. The Jensen JT-11P-1 is a pretty good line input transformer. It's about $60.
