Changed the diodes, no luck.
However, I discovered something ..
My headphone is Takstar 82's implementation á lá Cooler Master MH-751 gaming headset, closed back. Unlike the original Takstar Pro82, it has a pot and mic-mute on its cable.
Well, 'til now I was always listening like pot at max here and at low-ish levels on my tube amp.
Now I discovered: if I turn down volume to pretty much (like 80%) on the headphone cable, I not only have a healthy large play between min and max volumes but my amp is dead silent.
WOW 🙂
For that recognition I at least changed the whole diode bridge, made DC heating and all those struggles since 2 days omg.
Uh. It was worth because of learning, for sure, but otherwise I might already had a reasonably good amp - we'll never know. 🙂
Now finally I can enjoy such a quality, ahh. It's always so stunning for me to hear these microdetails, crisp clear highs and tiniest nuances in the upper region.
I was missing my little baby. 🙂
Cheers Guys and I really appreciate your instant help with the hum pot. This will definitely serve me well in the future for my next builds.
Have a great Summer, enjoy music 😉
(Needless to say, all tubes are behaving OK).
WOW 🙂
Thanks for the links. On my other to-be tube amp's power transformer when I tried .. DC was not enough from 6.3V AC tap. Luckily I was thinking ahead and not only overspecified the needed currents but also had a 9V tap - actually, a 9V secondary with 6.3V tap. Anyway, from that 9V there was absolutely no issue on DC, stabilized, I set it to 6V, that's it. Fire & forget. 🙂
Here, the 6.3V AC gives me fully loaded ~6.45V DC.
Perfect. But need to replace the FR607 diodes. They're hot like hell. I mean really hot.. I felt the heat while looking into the amp closer, on my face. I was like wtf, 6A diodes struggle with 3A ? But yeah, apparently. 15A Hexfreds will do the trick, same ultrafast types as in the anode section now. (The latter are not even warm, okay, eating 0.3A only but still).
