J-P, will it have analogue out only? I didn't spot an output spec? But I see A/D so I suppose it's A out only, or?
/J
Indeed it's only analog output....
Digi out? maybe.. later... eventually ..?
Why do you want digital output? We will have great D/A converters and a good clock with very low jitter....
Jan-Peter
Digi instead of speaker cable... I'm in possession of the one of the best D/A ever... but maybe it's time to let go..
If You compare to GroundSound equivalent... why this one ?
We have our own design philosophy, but basically it's a 2-channel input and 6-channel output with DSP (two!). There are more suppliers out there who has this too....
Jan-Peter
Jan-Peter
What's your approach with the analogue processing after the DAC's? Op amps etc?
OK - thanks for your replies! I will be checking for release and price? Btw - is it estimated yet? /J
BTW = VAT which is 19% for EU buyers.
Indeed after the DAC we use high performance op amps. We use the OPA1632.
Can I suggest we continue discussion of the standalone DSP in its separate thread over here: http://www.diyaudio.com/forums/digital-line-level/164277-hypex-dsp-module-s.html
There are a couple of programs that can create the impulse file which can be imported into the Hypex filter program, I will post them tomorrow because today I am working at home.
But we are going to build a import function for .frd files, there files are more common.
Which program do you recommend for measurement files?
Important is to compensate the errors of microphone frequency response by a microphone calibration file. HOLMimpulse is a freeware tool which deliver this feature. Please check whether the maesurement data format is compatible with Hypex.
HOLMimpulse download HOLM Acoustics
Ruediger
I want to get either the AS2.100 or the PSC2.400 but am still undecided which one would suit me better. I don't need the subout of the AS and prefer the balanced operation of the PSC, but don't really need the power of the bigger module. That's also what worries me a bit about the PSC: I will run the modules digitally and have very sensitive drivers, meaning I would only need a fraction of the PSC's power. How would that affect the signal quality? If I run a PSC at very low volumes in the digital domain there will only be a few bits left at the amps. It's been said that dithering is the key, but that would need to be a LOT of dithering, if a 400W amp is only outputting, say, 2W. That's why I'm leaing towards the AS2.100 although I prefer the feature set of its bigger brother. Any comments on this? How does the PSC2.400 handle very low signals?
The most important thing to rectify here is the notion that you need "a lot" of dither. There is *only one* correct level of dither and it relates to the size of the LSB. It is not signal-dependent. So once you have 1LSB dither in place, all quantisation noise sounds like analogue noise, with no loss of "resolution" whatsoever. You just get a steady hiss, just like in the analogue world.
Actually, since all converters are 24-bits but are rated in the 100dB SNR range, the analogue noise fully dominates anyway, by several orders of magnitude in fact. SNR fully accounts for what you hear.
Having said that, extremely efficient drivers will make the background hiss noticeable. If we had to design the PSC/AS modules for use with very efficient drivers we'd have had to use much lower noise converters, which would put the modules in an entirely different price bracket altogether. So your intuitions about efficient drivers are correct insofar as noise is concerned. As far as loss of digital resolution is concerned, that problem is nonexistent in these modules.
- Class D
- Hypex UcD AS2.100
