IRFZ44N
Aren't these still available at say DigiKey?
If I recall these devices are supposed logic level threshold switching devices. (the compliment device code escapes me at the moment) IRFZ5902???
I used a pair of each (Pch and Nch) to build a H bridge for motor control.
I have a pair, used, but as far as known still perfectly functional.
The IRLZ44N are the low-threshold.
Ahh yes, it's been many years.
Jan
IRFZ44N datasheet
Equivalent transistors link...
MOSFET Cross-reference Search | Equivalent Transistors
Arrow has stock..
https://www.arrow.com/en/products/irfz44npbf/infineon-technologies-ag
Arrow has stock..
If you use the FETs you have on hand, you will need to use a lower value gate resistor. PPI commonly used 22 ohm. 47 ohm would be a good choice. Anything up to about 75 ohms should be OK. If there is enough deadtime programmed in, you may even be able to use the 100 ohm gate resistors.
Thank you for the link, neonarossa.
Very welcome.
One last question concerning IRFZ44N. I was looking into ordering them but neither Mouser or Digi-key has them in stock. However they are both showing as having IRFZ44NPBF in stock. Not sure what the "PBF" stands for. Is there any difference between IRFZ44N and IRFZ44NPBF?
The PBF stands for lead (PB) free (F). I always buy the IRFZ44V for rebuilding power supplies, it just looks to me the best performing one for the money. I think the letter at the end (N, V, or whatever) is maybe the revision, so possible that V is newer than N? Mouser and Digikey both have lots in stock.
I was advised to use IRFZ44 for PPI amps using the SG3525 with 100ohm gate resistors - this was for the M/AM series however. I was told the IRFZ44N's could cause issues.
PPI used different fets throughout production based on what they could get at the time. I have seen IRFZ48's with 100ohm gate resistors used in the A series as original equipment. They used different fets with the same drive circuits through production also. I imagine as long as the drive signals are clean in circuit it will be ok.
- General Interest
- Car Audio
- IRFZ44N replacement?
