Is 28AWG silver wire OK for connecting caps
I'm adding more caps to my crossovers and have some 28AWG upocc solid silver wire. Is that wire OK to connect the caps to the 18AWG leads going to the AMP inputs and speaker outputs.. See attachment.
I just happen to have a few feet of the silver wire that I bought fifteen years ago to make some interconnects. I'll never use it again so it's not a waste to me. I'l have to find out the amps that would go through the caps in the crossover powered by my Parallel86 amp
Ohms law lets you do it. Start with the max wattage of the amp to be delivered to the driver. That chart rates continuous current not the intermittent current seen in speakers so the wire can handle more. The resistance is more important as it effects everything. A short piece will have very low resistance so the bottom line is don’t worry about it and just use the wire!
