I use the IRF3205.
Hi Perry,
I have the power supply FETs, I meant the transistors that drive the power supply FETS. one is labeled CHC and the other is a BD, I was wondering if you have the part number for some equivalent transistors that are readily available.
For the output it uses IRF540z, would it be ok to use all 540n or 540? the IRF540Z can handle more current.
My mistake. I use the 2SB1260 and the 2SD1898. Someone else stated that they used the 2SA1797 and the 2SC4672. I've never used those. I've never had any problem using the ones I listed.
For the outputs in any class D amp, I'd suggest using exact replacements. Some amps are finicky. If you use something different, I suggest thorough testing.
I don't have the original numbers for those. You can start looking here.
Маркировка радиодеталей, Коды SMD BD, BD*, BD-, BD-***, BD=***, BDR, BDS, BDT, BDU, Bd. Даташиты BCW61D, BCX54-16, BCX5416TA, BD4722G, BD48E40G, BD48K40G, BZT52H-C6V2, KDZ22B, RP130Q241A, RT9011-GKPJ6, RT9011-GSPQWC, RT9013-2HGU5, RT9013-2HPU5, RT9169-24PX, RT9193-28PQW, RT9818G-20GY, TPS61020DRC, TPS61024DRC, TPS61025DRC, TPS61027DRC, UDZ6V2B.
Awesome! Thanks for the info. I will order the IRF540Z and the transistors you provided. Can I use these as power supply drive transistors on other JL slash series amps?
I was able to find these available from my supplier. good?
2SB1260T100R
2SD1898T100R
- General Interest
- Car Audio
- Jl 500/1 Power Supply Drive transistors
