Jl Xd1000 low power
I have a JL Audio XD1000/v2 mono sub amp which powers on and produced audio but it's not making anywhere near the power it should be, it struggles to power a single 6x9 speaker even at full gain.
The amp is stable, doesn't overheat and internal visual inspection of the 3 boards and connectors appear fine.
Any help appreciated, thanks
Check the voltage input switch. My guess is it's set to High, when it should be set to low.
I'm assuming your input source to the amp is RCA's coming in from an aftermarket head unit? If so, those RCA's typically only produce up to 3V.
The input level switch should be set to low when the input to the amp is coming from "...Conventional preamp level outputs"
The input level switch should be set to high when using "high-output preamp level signals as well as speaker level output from source units and small amplifiers"
See page 7 of the amplifier's owners manual.
