If low cost amp for example, sounds indistinguishable from expensive amp without peeking, then what is consumer losing really?The retailers go out of business but the consumer is to blame for only buying the lowest cost.... comparing prices. Instead of comparing performance, reliability, quality, etc.
That just shows that blind testing is bogus.
-RNM
Bogus argument.If low cost amp for example, sounds indistinguishable from expensive amp without peeking, then what is consumer losing really?
-RNM
Home audio systems, including those tied into an outdoor cable/antenna/whatever requiring safety Earthing before entering the building, don't really need anything special to control safety ground interference loops. Everybody plugs into the same AC power strip, making all their safety ground loops local and negligibly small. The shield of the cable/antenna/whatever is also connected to the power strip's safety ground. Small local loop and can be reasonably lossless for signal.
All good fortune,
Chris
All good fortune,
Chris
At least that only contains one negative instead of fourThat just shows that blind testing is bogus.
Bob Carver successfully did indistinguishable enough a couple of times.What about listening test with peeking?
Only to those who sell expensive audio electronics.Bogus argument.![]()
You wish
-RNM
Not a wish but an observed pattern. However, you wish otherwise.You wish
...I note that HDMI to single mode converter pairs start at around $140. Wrong point in the chain for many of us, but might be of interest for those with home theatre rigs.
I had a lightning event which started at my TV, followed both HDMI and ethernet cables into my house networks and wiped out a metric $#!tton of stuff. My TV is now isolated via both optical HDMI:
https://www.amazon.com/AV-Access-Fiber-Extender-4K60Hz/dp/B073QLRJDR/ref=sr_1_3?keywords=fiber+hdmi+extender&qid=1570309994&sr=8-3
and optical Ethernet:
Fiber to Ethernet Media Converter | FS Fiberstore
I rest a tiny bit easier...
Howie
Funny but great reference! I wonder if Reich was an audiophile? Anyway such a great band...we almost got Nik Turner's Space Ritual here for ProgDay...but apparently US Customs frown on admitting people with drug raps...
Cheers!
Howie
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
