Thank you! I thought it was an analog one...i don't understand this language unfortunatelyFull 1920000 point FFT, removing all bins over 22050 kHz and doing the inverse FFT. This gives a "perfect" filter with -300dB out of band and an 0.1Hz transition.
Some people claim alien abduction.
At least PMA can hear the different of cymbal recording at 44.1 and 96 and you don't. You will call PMA an alien?
Maybe PMA just a normal person, and you are....
People hearing things that nobody else can hear reminds me of people with a firm believe that they are clairvoyant and see things that others don’t.
Hans
Usain Bolt maybe an alien who can run 100 m at 10.49 second.
Here is the magnitude of the two signal envelopes and the difference in red. The Gibbs effect is obvious in the filtered signal but there are differences that are clearly at frequencies well below this.
![wave :wave: :wave:](https://files.diyaudio.com/forums/images/smilies/wave.gif)
![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
THx-RNMarsh
Suggest this work be turned into a paper for publication (AES? IEEE? EDN?)
Ditto JN's study.
Finally, getting some info that could explain hearing differences besides just looking at thd/IM and FR etc.
Not sure anyone is still interested in the last discussion concerning the cymbal soundfile. To my surprise removing the content > 22.05kHz effects the amplitude envelope more than I thought. By amplitude envelope I meant the magnitude of the analytic signal from the Hilbert transform. When you simply mix (add) two sines the envelope is perceptible, I don't know why the conversation got so derailed.
Of course, I still interesting.
PMA proved that he can hear the different.
It proved technically that envelope is different.
You can ignore who can not hear the different and concentrate in technique/science.
Don't take it so serious. Technically worse, with worse parameters, is often preferred by listening.
It is true. Absolutely, agree.
Still interested. JN et al got tired of being trash talked to.
THx-RNMarsh
For noise voltage 10Hz-100kHz :... it's only noisy as hell...
National, TI and NJR 7805 datasheet quoted 40uV
LT1693 LDO datasheet quoted 45uV (the one Markw4 compared with on the AK4499 eval board)
What do I miss?
I didn't even bother...some people hear strange noise just by looking on their analyzer screen.For noise voltage 10Hz-100kHz :
What do I miss?
Actually it's 45uv for the NJR part, but PSRR add up too.Just use bigger capacitors in and out...I've seen 10uv noise for 10v output /10w/10 days up to 1mhz smps power sources, but they weren't for sale...
I'm having trouble imagining what the envelope of a chaotic waveform means from an audible perspective. Calculating the envelope is a (highly) non-linear operation that introduces new frequencies. Differencing the envelopes in this case produces a spectrum from DC to Nyquist. What is the significance of that?Here is the magnitude of the two signal envelopes and the difference in red. The Gibbs effect is obvious in the filtered signal but there are differences that are clearly at frequencies well below this.
You lose nothing by ignoring his witch hunts.What do I miss?
It is enough that someone he hates has said something for him to take the opposite side. A unique party, of course.
Here, he strangely puts on the boots of a behavior usually attributed to audiophiles: the more expensive the better.
We now still have to analyze the influence of the feedback loops from regulators on the way the sound of the circuits they supply is affected.
With a slight flick of the wrist, wizardly prestidigitation. Performed effortlessly.
Scott,
Interesting image.
It is obvious that the envelope changes when reducing the frequency content.
It is also to be expected that Gibbs ringing will be added to the filtered signal.
Could you additionaly make a plot of the signal’s magnitude, its HP filtered version from 0 to 220500 and their subtracted difference ?
Hans
Please, consider 3 things:I'm having trouble imagining what the envelope of a chaotic waveform means from an audible perspective.
1- What you qualify of "chaotic" is called transients.
2- Our hearing system has adapted, during a long evolution, to offer us the maximum chance of survival: It is perhaps more sensitive to these transients than what you imagine: the sinusoidal signals that we use to determining our limits of perception of high frequencies do not exists in the nature.
3- Between the electric signal and our ears is an electro acoustic transformer called a "Speaker". How the slew-rate of a transient signal affect its responses ?
The problem with your question is included in the word "imagine". You just have to make experiments, listening by yourself, to figure out if it makes, or not, a difference for you.
To answer point 3, I suggest a fairly simple test: Compare the acoustic differences (with a microphone rising fairly high in frequency) between a sinusoidal signal and a square signal at 12kHz, applied to your speakers on an oscilloscope.
Scott,
Just one more question.
I heard you mentioning the use of Hilbert afair.
Did you really use this ?
After filtering the complex Fourier transform of the time signal, when going back to the time domain, all that has to be done is to calculate the inverse Fourier without Hilbert.
Or did you use the magnitude of the Fourier transform in combination with Hilbert.
In that case you will create a slightly different time domain signal IMO.
Hans
Hans
THx-RNMarsh
Ditto JN's study.
Richard, this is observable with an incredibly long FFT. Will this happen with ordinary D-A’s?
Just posing the question.
Back to 78xx style regulators. I actually quite like the 7815 - it’s about 1/3 the noise of an equivalent 317 reg circuit and great for general purpose work. I would not of course use it to power an MC head amp. I always use split secondaries and rectify, smooth, regulate and then combine to form a split +- supply so I therefore only use one type of regulator IC.
Opamp PSRR is so good now that 100uV of PSU noise ends up buried way, way below the noise floor of any line stage or MM EQ amp. Decent decoupling and layout all have to be beyond reproach of course.
Gibbs phenomena
Gibbs phenomenon - Wikipedia
Am I right in saying this phenomena is only observable in discontinuous functions - ie like a square wave? It is not an issue in continuous functions where the Fourier series converges more quickly?
How about capacitance multiplier after 78XX regulator? It is good enough?
THx-RNMarsh
Ditto JN's study.
Without knowing what you see and why, you already tend to jump to conclusions.
Hans
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part IV
