Kef 104/2 T33 Tweeter Mutant Euphony
Just to pass on my experiences with KEF 104/2 T33 Tweeters.
I have owned my Kef 104/2 since 1996. They are 1st revision? With Gold speaker connectors,Rubber bass unit surrounds but not the bi-wire.
I always felt the top end was lacking compared to the LS3/5a. I ended up using a pair of Tandy Linaeum Ribbon Tweeters bought cheap when Tandy UK closed down.
Have tried other tweeters in place of T33’s as per the many recommendations on the internet, Morel, Peerless et al but felt none kept the same smooth sound, most adding a lower treble hardness.
So to the point of this post. I recently fitted a pair of Mutant Euphony 6.5” speakers in the rear of my car, after 3 failed attempts at getting the sound right. These were excellent despite Mutants reputions for cheap speakers. Almost like the Kef B110 I had fitted as a temporary measure.
So had I two Tweeters spare from the kit. Size of the Silk Dome was identical to Kef T33. (Looked identical) with High power handling and at 4ohms, the specs looked good. Neodydium Magnets so much smaller diameter.
Well, fitted them with the casing and their diffuser grille which gives the ability to rotate axis of tweeter.
All can say is wow! Sound is like before but with a beneficial increase in the upper registers.
These are discontinued now but should be readily available. I Paid about uk£35 for the whole set of 6.5” Tweeters Crossovers as a Car kit.
Hope this helps.
OK I figured out how to test with a multi meter and an AA battery. The blue wire is positive and the brown is negative (ground). I attached the + lead from the meter to the + jack on the back of the speaker. I touched the + side of the battery to the blue wire for the tweeter and the - lead from the meter to the - side of the AA battery. I get a 1.4 read. If I use the brown wire from the tweeter to the + side of the battery i get a -1.4 read. - meaning out of phase. So KEF C60 speakers blue = +, brown = -.
Hello !
I bought a second hand KEF C30, and the blue was connected to the red pin of the tweeter in both speakers ... BUT i don´t know if someone opened them before..
Anyway, if we look at the crossovers, it´s noticable that the Blue Wire is connected do the Black Connector in the rear of these KEF C30
So, i´m confused 🙂
KEF C60 CROSSOVER SCHEMATIC
Just posting KEF C60 crossover connection and documentation, original from KEF UK Company hope it will help, i see many people asking about plus and minus connection of the tweeter KEF T33,and wires color,
i hope it will help😀:cheers:
Resistor values?
I just re-capped a C60 crossover, and I can confirm, based on the crossover markings:
Blue = Negative (-)
Brown = Positive (+)
Purple = Negative (-)
Red = Positive (+)
Hi! I tried downloading the schematic on this thread, but it’s damn near unreadable. I’ve got a bad crossover in one of my C60’s and just on visual inspection I’ve got blown resistors at locations R1-R3 & R6-7. I realize this is a few years old, but I’m hoping you had the values you used when you recapped? Thanks!
