Hi Morten,
thanks for your reply - in the meantime I was also certain that they are both coupling caps - however the question is still , if the different values you used will have an impact on the frequency response or have they been originally just overvalued.
Do you still use the VS ? Did you do any more changes ?
Thanks & best regards
Peter
Peter
Hi Peter,
No impact on the freq response. The caps ''see'' a fairly high impedance and therefore does not need to be that big.
I have not done more mods, than you see here in the thread (and I don't know how more would fit inside the box) 😉 I'm especially pleased with the 24 position switch I implemented for cartridge loading. I have used that a lot since the optimum loading is critical with some cartridges - for instance VDH that I use.
See this thread... I'm on my way out of this bizz... http://www.diyaudio.com/forums/diy-hifi-supply/156854-dht-otl-linestage-tram-2-a-98.html
Hi Morten,
oh -so you make a quite hard cut now ..... I am also loosing more and more the fun in finding the best equipment - in the last weeks I was just listening to music - I hope the VS is the last step I do now ;-)
All the best for your journey !
Peter
Peter
I guess you can call it a hard cut, but it does not feel like a hard cut to me 🙂
BTW: I was just reading your previous posts again, and I notice you have hum and want to build a bigger box... This should not be necessary. Mine is completely quite with no noise or hum at all. And that is on MC with the step up's at the 1:40 setting (worse case scenario for hum).
I also made a hard cut in the last weeks - bought a Klipsch Cornwall and a Solid State Amp - did not even try some of my tubes anymore. Thats why I have the VS sitting here since a while and all upgrade Components (Caps, Casing , transformer) and not even started to built it. Listening to my old Aqvox Phono is good enough don't even bothering of what might be possible with the VS - maybe in winter I will built the VS 🙂
