LM386 alternatives?
ainami said:
I'm looking at a headphone amplifier kit which uses an LM386 as the chipamp. Could anyone suggest a better quality amp that could be swapped in the same circuit?
The best alternative would be to ditch the LM386 and find a circuit that doesn't use an output capacitor.
Why did you choose that project?
If it's for sound quality, something like the buffer combo we usually talk about here, with OPA627 + BUF637, will sound a lot better than this circuit.
Carlos
motherone said:
I'd recommend looking at Tangent's mint or pimeta boards.
http://www.tangentsoft.net/audio/mint
http://www.tangentsoft.net/audio/pimeta
Both of these are reasonably low cost and fairly high-end compared to the "single op-amp" based headphone amplifiers.
I don't have any association with tangent other than having bought his products and being a satisfied customer.
Thanks! This is exactly what I'm looking for. I did find another kit, but it's probably overkill:
http://www.audiokits.com/products.asp?prodid=395
Thoughts?
It looks interesting indeed. Probably an Erno Borbely design. You will have to spend something more on the supply, which on the other can be a battery one.
Tangent's or Audiokits' are probably the way you should go for serious headphone amps.
Carlos
