PARTS EXPRESS: C-Note MT Bookshelf Speaker Kit Pair with Knock-Down Cabinets are on sale for $100 per pair, which includes cabinets, ports, and all crossover parts required to construct one pair of speakers. List price is $220/pair.
Larger than your goal. Dimensions: 11" H x 7.5" W x 9.5" D
"Dayton Audio's DSA135-8 5" Designer Series woofer is used for the midrange and low frequencies. With an aluminum cone and a powerful motor designed for low distortion, this woofer produces bass with authority while remaining smooth through the midrange frequencies. The high frequencies are handled by the ND25FW-4 1" soft dome tweeter, also from Dayton Audio. This waveguide-loaded tweeter controls high frequency dispersion for smooth off axis response and natural sound. Another advantage of the waveguide design is that it allows the voice coil to set further back from the baffle for an almost perfect time alignment with the woofer."
Specifications:
• Power handling: 60 watts RMS/120 watts max
• Frequency response: ±3 dB from 43-20,000 Hz (±2 dB from 60-16,000 Hz)
• Impedance: 8 ohms
• Sensitivity: 85 dB 1W/1m
• Dimensions: 11" H x 7.5" W x 9.5" D
Not exactly on sale. They’ve always been $100. That’s why they’re called c-note = century-note or a one-hundred dollar bill
I think it is a great little speaker though, going by the numbers. I plan to in the future build a pair of those
