Looking for feedback on my DML instrument amp
Inspired by the Voix du Luthier, I want to build my own instrument amplifier using audio exciters and a wood panel and I'm looking for guidance. I plan on using two 40w Dayton Audio exciters. I want to build the preamp myself and will likely use a class D power amp module. I'll be playing electric and acoustic guitar, synths, drum machines, possibly bass through the amp. Ideally it will be loud enough to play with a considerate drummer (say as loud as a princeton reverb)
I imagine the signal flow will look like this:
Input buffer -> Preamp -> resonant sweepable HPF and LPF -> Power amp module
The input buffer is there to accommodate hi-z and line level instruments. The preamp is for initial tone shaping. The two filters are important because they can be dialed in to approximate the frequency response of a guitar speaker or used for further creative tone shaping. This then flows into the power amp module
A few questions:
  1. Does a preamp differ from a tone stack? Can I build a 3-band fender tone stack and consider it my complete pre amp stage or is there more to it than that?
  2. Any recommendations for a solid state preamp stage for this project?
  3. Does the order of my HPF and LPF filters matter?
  4. I'm considering the ICEpower 50ASX2SE as my power amp, is this overkill for my project? It's expensive but I am most concerned with reliability. Any other suitable and more affordable replacements?
Any thing else I should take into consideration? Thanks for any help you can offer!
Cool, I understand the preamp a lot better now. Still looking for the right circuit but this will take a lot of experimenting, same with the filters.
I've actually pivoted the power amp to the Wondom AA-JA32173, that's their 2 x 50w amp with the JAB3+ chip. The DSP, battery power, line out, bluetooth and ability to sync another amp have me convinced unless someone here has a reason to choose otherwise.
I'm looking at the Meanwell Lrs150 power supply to power the Wondom amp and battery pack. Will this work?
https://www.meanwell.com/productPdf.aspx?i=420
