Looking for schematic Millbank Talisman II DLS
I have a Millbank Talisman II amplifier, which is blowing its fuses.
It would be great if someone had a schematic, or an advide how to repair this kind of amplifiers.
This Talisman II amplifier is of the type Dynamic Loop System (DLS), and is constructed to feed a hearing aid loop in a meeting place.
The end stage transistors are 2 times 2N3055 and 2 times 2N3055H.
When the two fuses just after the rectifier/Elco's were blown, I replaced them with new ones.
After switching on, the amplifier became hot, smelled, and one of the fuses is blown again.
To fix this, I am looking for a schematic, or - even better - a repair manual for this kind of amplifiers.
Thanks for your advice. In order to check for shortage of the transistors, will it suffice to use a digital multimeter in resistance mode, or do I need to test with higher voltages? The amplifier is 25 years old. Would it be a good idea to replace the 4 To-3 devices by new ones (of the same batch) or even by other types with better quality?
