Low noise LDOs for DAC
I'm building a DAC and I'm looking for some advice on power supplies. I noticed that some designs focus on using very low noise LDOs. Is there really a noticeable difference vs using jellybean LDOs with proper decoupling? Which characteristic of LDOs is more important (RMS noise, PSRR etc)?
It seems that LDO (Low-dropout) has become a synonym for regulator 😉
Power supply requirements are dependent on the DAC chip. Low output impedance benefits most if not all DAC chips. Older 16/20 bit DAC chips do not necessarily benefit from ultra-low noise regulators. With delta-sigma DAC chips to reach datasheet performance ultra-low noise regulators are needed but typically only for critical supplies (voltage reference).
LDO (low-dropout) regulators are especially useful for DAC chips operating at lower voltages. E.g. for using 5V input to power a 3.3V DAC chip.
Reactions: jan.didden
I guess LDOs are the industry standard now for modern regulators?
The DAC only asks for a low output impedance regulator. I've used jellybean 78xx/79xx regulators in all my analog designs without any issues, sometimes even switching regulators. But I've never built a DAC.
