Hey you guys who have fixed Marshall AVT Amps!
I got the schematic from Enzo - MANY thanks but my problem is locating things on the main PCB.
My 40, 0, -40 main power supply is FLOATING (at 2/3 of the ECC83/12AX7 B+ above chassis).
Thus the conducting path clearly shown on the schematic is open.
The path that joins the centre-taps of the two transformer secondaries.
But I have searched for many hours and cannot find any such connection (track or link) either on the main PCB or via any other board. Nor any sign of a burn.
Is it hidden under that muck they use to glue the smoothing caps down?
Many thanks
Many thanks
i have a avt50 that has some burnt resistors in it and was wondering if any one could send me the schematic
thatks
espwithemgf50@aim.com
thatks
AVT-50 Schematic
Hi all...I am troubleshooting the Marshall AVT-50 (no output) and in need of a schematic. I have tried some of the links posted elsewhere here, but I guess they're all must be outdated. If anyone has a copy, please post the link here, or better yet, please send to my email address at danielnguyen69@yahoo.com. Much appreciate !!!!🙂 😕
Marshall AVT50 schematics:
http://web.archive.org/web/20071015...guitarist.com/schematics/amps/avt50_60_02.pdf
http://web.archive.org/web/20071015104455/www.indyguitarist.com/schematics/amps/avt50_61_02.pdf
http://web.archive.org/web/20071015104956/www.indyguitarist.com/schematics/amps/avt50_62_02.pdf
AVT 150 H pin arrangement
hello there, I am in need of the AVT 150 H pin arrangement from the amplifier. I bought the amp without a footswitch or cable. I then bought the footswitch and got the pin arrangement from that but cant find the pin arrangement in the amp. if anybody could help it would be amazing.
thanks
thanks
MARSHALL AVT50H SCHEMATIC
Help, can anyone supply me with a copy of AVT50H schematic, checked forum and tried number of links without success.
Mike
Mike
AVT50H
Hi
Just received a copy of AVT50 schematics from Stephen H, anyone else want copies please post email address and I will forwards.
Mike
Hi
Mike
Hello I would absolutely appreciate a copy of the schematic for a Marshall AVT50H. . . My email is aalvarez.turtle@gmail.com I appreciate your time ! ! !
Hello!
I would also like to have a copy of the schematic for the AVT-50h if I could, please.
Thank You!
maxti6@aol.com
Thank You!
maxti6@aol.com
I seem to be having the same problem with my AVT-50h.the reverb box came loose inside my amp and the screws shorted it out...anyways, i'm trying to fix it and it'd be a lot easier if i could get a hold of the schematic...
can anybody help?
No reverb at all.
Any help with this fix would be Greatly Appreciated!
- Live Sound
- Instruments and Amps
- marshall avt50h schematic?
