well I already managed to generate the 79.8 v rail by removing an lm2901d that is next to the hip4080 I am buying it now but I still can not make the led turn on I do not know if this lm2901d is the one who manages it according to me not since the one that handles this next to the mic4424cn that I should check right away
If apparently in this case is ic6 is the one that withdraws and stopped shooting under pin 8 and worked to give the almost 80v rail now I see that sends part to the ic3 to be specific to comparators 2 and 3 in this schematic to it looks like something different pin 8 of the Sg3525a goes to a diode and a capacitor I hope with the change back to life this nice device I still need to make known the progress
I already changed the lm2901d but I still can not get it out of his dream the amplifier still can not turn on the led is connected to pin 1 of the lm2901d here are the voltages that is what is wrong?
I do not know I've been looking for that fault, I think it's the origin of all my ills, all ICs referring to comparators and operational amplifiers (lm2901d, tlc2274c and lm837m) are like this (0v in vcc +) I can not find the reason for the lack of voltage today I keep looking for the head, tomorrow I will not surrender right now so I will give another revised to the schema of the earthquake
ready has been solved and working would not know how many watts rms throws because that equation is not removed accurately and for the moment I do not have an oscilloscope so I would not know what is the clip of this amplifier in order for a summary to work made change of: 2 voltage comparators lm2901d. 1 pnp transistor 2n4403. 1 HIP4080aip. 2 resistors 13fr020. 8 mosfets irf3710z. 12 mosfets irf3205. 1 b103 potentiometer is the gain level. 1 Sg3525a. 2 resistors 10 ohms (180 and 181). good to thank you for all your support Mr. Perry Babin.
- General Interest
- Car Audio
- Mmats pro d2000.2
