Mosfet irf9530
Can you describe what they might look like. I looked up all the chips I can see and they are op amps an one on amp. There are two units in the center of the board that look a lot like the mosfets but I can't see what is printed on them.
Here are some photos. I don't know how to pull this board off the plate. I tried cutting the black adhesive material with a hobby knife. I suppose I will have to separate it to get better pictures.
What we want to see is the pcb area behind those big black filter capacitors… upper right corner of the pcb. You will probably see IRF530/IRF9530 output mosfets there with lots of smd devices in front. Be careful with knife...that black adhesive material is really pain the *** to remove...don´t brake anything.
The only things back there are in r107 and r108
the printing on them is 3321 and 32r1. I think. They are very small.
I believe 3321 is a thin film resistor and 32r1 is a current sense resistor
