my "little" build
some pics from the sub i just built. It's in the testing phase right now so no paint or finish shots.
Oh yeah, you'll notice i didn't use the first set of bottom curve I made but since the process was the same i didn't bother with pics.
it's for a Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series in a 6ft^3 box tuned to 15Hz. after about two hours run in I took it for a spin, It is a beast. 12down is at ~12Hz 😀 and in room 2db down at 20Hz, at 105db/25Hz the port makes no extraneous noise, nada.
pt 2
Here's the in room. I'll take it outside tomorrow. 😛
the wife is home I had to keep it down 😀
edit: the graph with the two separate plots are near-field (6") in 2db increments.
