Hi there,
I'm very happy to find this forum and especially this thread! So glad to have found the nad214 schematics on your website ACD - however does anyone have an easier-to-read copy? I'd like the service manual also, if possible!
If you have either, please send to: PhilNad214 AtGmail dotty com (sure that's understandable ;-) ).
I have two dead nad 214 amps...
The first 214 suffered some water damage a few years ago, but the only problem was (when turned on) a 'whistle' for a few seconds as it warmed up. But gradually it developed some white noise. I sent it off for repair and several $100 later is appeared fixed... but noticed the 'soft clipping' circuit was on - after switching off I found the problem was still there. After about a year the amp gave up totally and it blows the fuse whenever turned on. Any suggestions as to where to start looking?
The second 214 died just recently (it had always worked faultlessly) - when I switch it on there is no click from the protection relay, so I guess there is something over a threshhold somewhere. This is whether or not any line-in or speakers are connected, or the soft clipping or bridged switches are on or off. Any suggestions?
Lastly, I studied as an Elec Engineer at uni, but I rarely tinker with electronics (other than building the odd off-the-shelf kits). However I'm willing to give it a go! So my first questions re. the 214 schematics may seem basic (so please bear with me) - sections like the power supply: the -67v rail - I assume this should be -67v even under load? But it must have a bit of variance - what is reasonable? Also for other test points in the schematic - what variances are acceptable when the system is or isn't under load? (These may be questions the service manual cover?)
Many thanks in advance,
Phil
