NAD Display Very Dim
I have an old NAD C521i CD player that I use occasionally & the display is VERY dim, in fact I thought it was dead but eventually noticed there was still some life left in it.
I have downloaded the manual but really for me it's like trying to read a foreign language.
It's not worth sending to the shop to get fixed, but I was hoping to keep it going if I can.
Does anyone have any idea what the problem might be?
I did find a thread from 2006 that I thought was going to get me there but it turned out the capacitors that the fellow replaced to fix his problem dont seem to exist in my player.
I think there should be a voltage of 3.3 - 4 V and another oven higher abt 40V, meassure the secundar winding on your trafo.
The big question is whether this is an LCD or a VFD display.
The LCD is backlit via small filament bulbs... a common problem.
The VFD (vacuum flourescent display) can suffer with low emmision, usually some segments are brighter than others and can "recover" after many hours use.
This type of display often suffers from "capacitor trouble" in the supplies derived to feed it... very common across all types of equipment that use this type of display.
If you post the circuit we can advise...
Without using a scope to see if there is any high frequency noise or ripple on the supply the only sure way to test the caps is to remove and replace with new (check by substitution).
R709 varies the supply available to the transistor Q520. I haven't read the manual... there may be a procedure for adjusting it but I would still change the caps first before doing anything.
Q520 forms a simple oscillator (with transformer M501) to generate a high voltage for the display.
Good luck... any questions just ask.
I'm not saying the display isn't faulty... it may be... but caps are such a common problem that it makes sense to check them first.
How important is it to match the capacitor values exactly?
No joy I'm afraid, I replaced the caps & there is no change. There is a ringing noise coming for the PCB somewhere in the vicinity of the larger caps on the baord as per the photo, any idea what that might be about? It's a bit hard to pin down the exact location
I not sure how successful this would be but I think it is worth trying to measure on your meter the voltage at point "ELD1" on the circuit in post #4. Make sure your meter is on AC volts and a highish range, say 200vac.
Also check the 9 volts is correct at the output of the 7809 regulator. Perhaps do that first. It should be spot on.
Hard to say what the ringing is... in general terms it can be typical of failed capacitor in any switching supply... and the EL driver is just that.
I was way wrong about the ringing noise position, it stops when I pull out the small power plug for the display, so its the display that's making the noise.
OK... if the output of the reg is at 11 v dc then there is a problem.
Can you make 100% sure on that reading. It should be 9 volts DC between ground and pin 3 of the regulator.
If its high then that is a sign of ripple on the rail and that could be cap C518 just before the reg.
Edit... did you swap that cap ?
I did replace C518
There is 11V on the leg closest to the front of the CD player, and 8.85V on the other leg
