Need some advice please fm-300A
after a evening of messing around with the amplifer board the only component the trim pot changes in the small device labeled 3090 its the small blue device close to the trim pot and i have trimmed them both too 250.0 mv
does anyone know what is the correct value please 😀
the 0.22 ohm resistors does not change with the trim pot
You must measure mV on the mentioned resistor. Set up your DMM to 2VDC and measure the changing voltage on the mentioned (emitter) resistor. Other option measure mA between the power transformer and the PCB plus connector. Of course you must disconnect the wire and use your DMM measuring mA. It is easy to set it up. Be careful with that trimmer because you can blew up your amp (do not just adjust without measurements). Also use a dim light bulb on the AC input to protect your amplifier while you set it up. See the att. picture. I hope this helps.
