Tad,
The image is pretty much scale. I routinely print out the PCB image real size and place actual parts on it and test for fit.
Q9 is probably too close to the output inductor wrapped around the resistor body. I should slip the inductor to the right a bit to afford a little more space between it and Q9. Thanks for pointing that out.
I'd be glad to send you gerbers if you are interested in building a protoype channel pair. I would feel much better about doing a group buy if someone has made a successfull build. Should I send gerbers?
"Any room on the pcb for a board mounted fuse holder?"
If we add fuse holders to the amp board we add 1 inch overall to width of the PCB. That potentially means one more inch to the overall depth of the chassis as well. My plan was to put fuses on the power supply board.
What is popular thought here? Put fuses on the amp PCB or on the power supply PCB?
Carl,
I was looking at the V+/V- trace and figured the fuse holder would somehow fit right on top of the trace. Some work of course, but it looked doable. I am by no means expert here so do not think I am being critical. Everything to date is fabulous.
The only reason I bring this up is I usually only have transformer, rectifier, wire, cap, board. That makes the mounting of the fuse holder an ITEM and not just a component. I will go with anything that you all decide.
I think Advanced Circuits has a deal for 33.00 on a couple of proto boards. Let me check it out and I will take you up on the gerbers. I can do a build and some preliminary cursory tests. Nothing clinical. Would that be sufficient information to proceed with. A few scope scans listening tests and component fits.
Thanks for the patience with my rambling. Tad
post 229 shows the regulated power connections +ve & -ve at opposite ends of the PCB.
The main advantage of a regulated supply is the low impedance at the regulator output.
One can only make use of this if the connections from the regulator are very close together, the connections onto the PCB are similarly very close together and the wires between the supply and the demand are very short.
The voltage amp demand traces are all centred in the PCB and would suit a twisted triplet located near the centre of the PCB.
AndrewT said:post 229 shows the regulated power connections +ve & -ve at opposite ends of the PCB.
On the other hand, if the PSU board was stacked on the main board There would only be tiny lengths of wire connecting the two. This would be simpler than redoing the centre board.
I have looked for a good regulated supply and have not found one as yet. Learning lots though.
Terry
but the regulator impedance would still be swamped by the hundreds of millimetres between the +ve , power ground and -ve.pheonix358 said:On the other hand, if the PSU board was stacked on the main board There would only be tiny lengths of wire connecting the two.
Stacking does not help where the spacing is wrong.
Andrew,
I have been searching around the web looking for reference material that would tell me what the VReg trace impedance would amount to. The closest that I have come to an answer (and I have little confidence in my findings) is from this page http://home.comcast.net/~pcb.george/trace.html . A 2 ounce copper traces that is 1.20mm wide and 100mm long equates to a .07 ohm resistance. If that truly is the case, do we have a problem?
AndrewT said:but the regulator impedance would still be swamped by the hundreds of millimetres between the +ve , power ground and -ve.
Andrew, I was thinking of very small leads connecting to a point between the two 47uF 35V caps for the +ve rail and using the 10R 1W as the lead to connect the -ve rail. Would this be a fix? All Carl would need to do is to put another pad in for the +ve rail.
Terry
Um, hello, is anyone out there!
We seem to have died
I know the Aussies had a long weekend last week, Queeny had a birthday, any excuse for a day off, hell mate it's Australia. Still got Lizzy as Queen, can't wait for Chuck to take the reigns, should be fun to watch.
Terry![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![bawling :bawling: :bawling:](https://files.diyaudio.com/forums/images/smilies/bawling.gif)
![smash :smash: :smash:](https://files.diyaudio.com/forums/images/smilies/smash.gif)
Terry
Carl I'd like to give it a try
can I get the Gerber files and such for the same ??
If you are not posting it here then perhaps can mail it to me at handsome1.blr@gmail.com.
Regards.
Regards.
I have no problem posting the gerbers, schematic and PCB layout files. That always has been the plan. I haven't done that because no one has offered the space to post them. If someone reading this has some space to volunteer please let me know!
SoundsGreat I will email you the gerbers and drill files.
Much Obliged Sir
I thought you were not interested in posting so only asked you to send it to my mail !!
Could you please explain what exactly do you mean by the "Space Offer" ?? coz if you want to upload the files you can use variety of online services like Rapidshare,meghashare,uploading,filefront,hotfile etc etc etc and post the link here
So I guess that problem is solved now ???
Regards.
Much Obliged Sir
![worship :worship: :worship:](https://files.diyaudio.com/forums/images/smilies/worship.gif)
Regards.
"if you want to upload the files you can use variety of online services like Rapidshare,meghashare,uploading,filefront,hotfile etc etc etc and post the link here ..."
I would rather put them on a site that is private, not subject to expire and not pounding the viewer with advertisements and distraction. Maybe it is me and evidence that I am getting old and cranky, but I find all of those upload sites to be really annoying ...
Am sorry if I said something wrong ! Yes what you say is to an extent true ! these sites can be bit painful at times !
Hope someone will offer you that much need space !
As for me,Am off to the PCB guy on monday to give the orders for the board
! cannot wait to finish it and hear
Regards.
![headphones :hphones: :hphones:](https://files.diyaudio.com/forums/images/smilies/hphones.gif)
Regards.
Carl_Huff said:...
Carl
I can host the files if you want.
Cheers!
![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
Files for download
Please note:
- The schematic can be viewed and edited using SPlan 6.0
- The PCB layout can be viewed and edited using Sprint Layout 5.0
- Both products quoted above are from Abacom online: www.abacom-online.de/uk/html/produkte.html
- The PCB should be made using no less than 2 ounce copper!
- This schematic & layout has been offered up to world as courtesy of Carl Huff and the DIYAudio community.
GERBERS
SCHEMATIC (PDF)
SCHEMATIC (SPlan)
PCB (Sprint Layout)
PCB (both layers)
PCB (bottom layer only)
PCB (top layer only)
PCB (photo bottom mirrored)
PCB (photo top)
Thanks Carl!![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
Please note:
GERBERS
SCHEMATIC (PDF)
SCHEMATIC (SPlan)
PCB (Sprint Layout)
PCB (both layers)
PCB (photo top)
Thanks Carl!
- New Amplifier - ULD Extreme
