So maybe the next version of Katana will have the same dimensions as the SBC, then we have two boards only?
Matt
Katana will not have a new version , just PCB enhancements . However we will make a new DAC only USB input based on ess9038q2m that is more "traditional". It will need a USB transport or just connect your laptop/phone
will this USB DAC be better than the existing Katana i2s?
No it will not be better...just easier to use , only one PSU
Will it have Katana technique like the Sparko output stages or will it be inferior to Katana?
Matt
It will have good but monolitic opamps
Pity,
will Katana when used with the new SBC have USB input via the SBC?
Matt
a single output stage?
hopefully it adapt two kinds of output stages.. for rolling
No further details at this point . We will give more info as we advance
Im curious.. will Allo solve its heating issues with Katana. I had seen a heating issue of your digione signature in computer audiophile thread.
to be honest... whenever I leave my allo products turned on.. I am a bit worried that my apartment may catch fire... (even with my replaced unit)..
any quality assurance measures from allo's part? we need a feedback from you especially when we buy the upcoming LPS..
Hi Guys,
In Katana documentation I read that the Rpi gpio pin that are used are pins 3,5,35,12 and 40. Is that all for signal?
What pin is used by isolator for power? 2? 4? or both?
What pin is used by isolator for ground?
I would like to connect pi to isolator using short wires to fit my casing model.
Thank you for your help.
Terry
Yes the pins of Katana are correct , for power isolator uses either/ both 2/4 (shorted internally) and all Gnd pins and also shorted so you can use any..
Hi Terry 22
DSD is not possible physically on i2s only DOP
Hi cdsgames,
I know about i2s limitation. I was thinking about some ak4137 embedded like terratechnos did with their Terra-Berry dac which can reclock upsample to dsd256 with great results.
Thank you.
It works great.
Katana with 3 good psu & usb bypass gives a fantastic music experience.
Hi cdsgames,
So PCM on i2s then resample to DSD and sent to dac ic ? I think thats what Mark is doing.
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
