does that mean "coming soon" is about to be replaced with has arrivedAnd boards will be available for EU?
Fantastic!!!!
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
![IMG_1233.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1233.jpg)
The chassis takes a standard Schurter IEC
![IMG_1234.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1234.jpg)
The rails are a bit to close to use a machine screw and nut, but using a sheet metal screw works great!
![IMG_1235.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1235.jpg)
Neutrik headphone jack
![IMG_1236.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1236.jpg)
![IMG_1237.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1237.jpg)
![IMG_1238.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1238.jpg)
The Landfall chassis requires placing leads on the pot, in order to get the pot on the centerline of the chassis. (It looks better that way...
![IMG_1242.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1242.jpg)
![IMG_1243.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1243.jpg)
Front panel
![IMG_1245.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1245.jpg)
Shiny chrome knob. With camera.
![IMG_1246.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1246.jpg)
Unfortunately, this knob was just a bit tight for that shaft, and though it went on with some, but not insurmountable, resistance, I just can't seem to get it off...
Oh well. It's not a bad knob.
![IMG_1247.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1247.jpg)
Wiring the jack.
![IMG_1248.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1248.jpg)
![IMG_1249.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1249.jpg)
Wiring the pot to the PCB.
![IMG_1250.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1250.jpg)
Signal input here.
![IMG_12511.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_12511.jpg)
![IMG_1252.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1252.jpg)
![IMG_1253.jpg](/community/proxy.php?image=http%3A%2F%2Forigin.dastatic.com%2Fforums%2Fgallery%2Fdata%2F500%2FIMG_1253.jpg&hash=ddbe468d5b8cbd4282f4ef6b06c4f31e)
![IMG_1254.jpg](https://origin.dastatic.com/forums/gallery/data/500/IMG_1254.jpg)
More assembly of the Landfall Systems Chassis. These things are sturdy when assembled!
meldano - We are looking into PCB production right now. I could have some in a week, but they would be quite expensive...
AndrewT - Again, I ask, what on earth are you talking about? The photos are hosted at diyAudio...the photos are not going anywhere. And if you are using that argument as a sideways complaint about long page load times, I've been dong it like this for years now, so I would suggest you avoid my threads, to save time.
At my end, I get told the pics are coming from origin.xxxxx.....................
That reads like a remote server.
We have hundreds of lost pics from remote servers that no longer serve.
If origin.xxxxx is a mistake and the pics are actually hosted by DIYaudio for posterity, then my comment was not needed.
Sorry if you had already attached.
A few more assembly pics -
The heatsink channel needs thermal compound to transfer the heat from the transistors to the chassis.
A thin coat on the entirety of the channel is a good idea. I use a brush to smooth it out.
The channel is threaded and tapped, the screws attach from the outside. Simple and effective.
- New PassDIY Headphone Amp (now available)
