Now it is possible to run lt spice in android mobile phone.
Download the winlator app file from github website and install lt spice & simply run it without any problem.
It worked perfect & smoothly.
Here are some prove.
Hi!
Do you access Android through keyboard, mouse and external monitor for this application?
I guess in order to run the app successfully your mobile phone should be on a high end class. Emulators drain lots of processing power, even in PCs.
I did not tried it yet but i sure it will definately work on it.Hi!
Yes mobile should have atleast 6gb of ram or good processor in order to run ltspice smoothly.I guess in order to run the app successfully your mobile phone should be on a high end class. Emulators drain lots of processing power, even in PCs.
Why would you do this on a device with a tiny screen and no proper keyboard though? Seems like a less productive approach for no benefit, unless perhaps you have to emulate circuits while hiking through the mountains and don't want to lug a laptop around? I get that its useful to emulate apps on phones, but there are more compelling apps you might want to emulate.
