Wonderful news! I hope that this one will be the real thing! I will cross my fingers and send out some prayers!!!![]()
Well, the boards are quite real, but I cannot make promises on any timeframe here, or other circumstances. I am not one for luck or prayers, but not one to advice against it either. It just may take me time to troubleshoot it. I have limited time and parts to work with.
Anyways,
This is a starting point.
![FullSizeRender.jpg](https://origin.dastatic.com/forums/gallery/data/2172/medium/FullSizeRender.jpg)
Anyways,
Thanks for the follow up info. I am following you here!
Russellc
Anyways,
Looks very promising!
![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
if you build it, they will come...Well, the boards are quite real, but I cannot make promises on any timeframe here, or other circumstances. I am not one for luck or prayers, but not one to advice against it either. It just may take me time to troubleshoot it. I have limited time and parts to work with.
Anyways,
Here is the right side channel built up and functional.
There is area to cover the transformer over which I plan to do later.
https://youtu.be/XLrI1UiYmcs
You can note how clean and organized my audio lab is.
I like the lab! "Order out of chaos!"
So that's where the magic happens teabag! Nice amp..!
I like the numbering on the opto! Stops you from putting it backwards![]()
Thank you. I put that on there myself, but I think going forward I might just sharpie a dot in there for people. Cheaper than retooling artwork and board.
The nice thing about white boards is I can write notes on them like paper.
So here is the a long demo, of the left channel board. Don't expect much bass with a near zero baffle 3" driver. But it does sound fine.
Both boards now work fine. I did manage to have an open channel on one of my transformers from desoldering or some other mishap, so I desoldered the working one gently and put into the left channel board.
https://youtu.be/1G0xWra-VFI
Same thing with this one R7 I changed to 52k to dial-in negative offset. Overall offset sits at 0.003-8
So I think this thing is good to go for a group buy. I would need Papa's blessing for it, and then I can start a separate thread.
Excellent. I ordered power transformer from Antek (500VA 18 + 18) and more wire yesterday. Are you going to list the parts you used? I have them all from the suggested list somewhere on this thread, but I like that offset figure and want to build as close to your version as possible to maintain those figures.
Thanks,
Russellc
Thanks,
Russellc
Video is private, can't watch it.Thank you. I put that on there myself, but I think going forward I might just sharpie a dot in there for people. Cheaper than retooling artwork and board.
I got the same message.
Russellc
Thanks,
Russellc
Sure I will put up a BOM of the parts I used in my build blog I am working on. They are by no means a recommendation, rather parts I trust to work, have low thermal tempco etc. When I get an extra signal transformer I will measure with FQA parts as well.
Russell are you using the 300mm or 400mm deep 4U Store Chassis?
I think 4U deluxe will be fine. I just used one for F-6. That is the heat sink I compared your boards pattern to.
yes, thank you. Please let us know if you want to make the boards for a group buy (or private sale).Can you see them now?
I will need Nelson's
Yes, that's more than enough.
Any progress with these PC boards ? I mean the GB...
Greetings
- Official M2 schematic
