Old FANE driver
I didn't find the 121/15 yet but what I've found are these drivers:
There's no paper note on the frame and the magnetic caps are missing but I'm pretty sure these are Fane drivers.
Does anybody know the driver?
Judging by the small magnet assembly, those are likely to be similar to the 122/10a twin cone drivers from the sixties.
EDIT: I should add that the magnet assembly is not visible in the image of my 122/10 single cone drivers because the assembly was enclosed by a plastic 'bucket'.
A difference is that my 122/10 drivers had cast alloy baskets, while your images appear to show pressed metal baskets.
That's what I thought but the 122/10a looks like this:
Assessing the size of the magnet my drivers could be 121/??a. Unfortunately there is no information on 121 models available.
BTW the catalogue from the 60s shows that models with a twin cone always had an 'a' at the end because of the aluminium coil. This 'a' is missing on the note of the 121/15. I assume that it must be from another era..
The 121/15 driver you pictured in post #1 has similar looks (basket and magnet cover) to this 122/14 driver which hails from 1975:
So, it looks like we should be searching the seventies!
Unfortunately, Fane do not keep records from that far back.
Reactions: IrieTim
Fane pop 12:50WRMS
"Fane Pop 50" is probably the correct name - a 12", 50 W, single cone driver. See the attached 1977 price list from Wilmslow Audio.
I am amazed to see someone asking £230 for one of those at auction, but see below*.
My 70s mobile disco used 4 x Fane Pop 60 single cone in concert with 4 x Goodmans Hifax treble horns - as well as 4 x Goodmans 12PD, 60W twin cone.
*The Goodmans 12PD retailed for £17.75 in 1977 which equates to just over £100 today!
