How much for 1 set ( 4 pcb)? thanks
Hi! price: On set (4PCB)
1. PCB- DAC END =15 $
2. PCB- Salas Shunt For DAC=15$
3. PCB- I/V stage =15$
4. PCB- 10M45 for I/V= 10$
I donation of $2usd to diyAudio.com , If you will buy 2 or 4 PCB!
Thank
Any interest for a Group Buy for AD1865-NK (best spec). Still available from Digikey. Minimum order 15 pieces. It is cheaper to order in the US than in Europe (20% value added tax) :
Digi-Key - AD1865N-K-ND (Manufacturer - AD1865N-K)
If someone would volunteer, I shall take 2 pieces. We can use this GB thread I started ages ago :
http://www.diyaudio.com/forums/group-buys/136518-european-gb-ad1865nk-digikey.html
Patrick
Patrick
There are no cheap AD1865s around, and you can search the forum for comments about sonic differences between different grades. I personally would only go for the NK grade. And I think the PCB is designed for DIP package anyway.
Whatever, there does not seem to be much interest anyhow .....
Patrick
Patrick
Hi quanghao,
I'm interested with DAC END. Pls count me for 1set (4pcbs). Can you ship to Singapore? Pls let me know the total cost and payment method. Thanks.
MartinTie
Ok! I can sent To Singapore!
thank! Lest You waite for me plesea!
Quanghao, I would like 1 set (4pcbs) plus 2 sets of output and output regulator. I am in the US. Thank you!
Ok! thank!
Ok! thank!
Iv stage Board
Quanghao, Are all these boards needed to make a Dac?
Is there a solid state output version?
Yes! but the I/v stage by SRPP tube is one otion! You can choice or No!
, I still do Iv stage, as the author- Andrea Ciuffoli use tube E182CC, scould I use a tube or other easy to find and cheaper!
But the sound is good!
Hi quanghao!
It looks like you have added an analog filter to the original design (on DAC board, choke and capacitor) ... Is that so? Why? And can it be by-passed?
Best!![]()
YES! That is one option, you can choice or no! I make it for many pople can use!
When You use I/v which tranformer you dont need filter.
You use I/v normal Tube or OP , you can use this option! If you like!
OK! Thanks! I'll order a kit when I can!
Hi all! At the moment the first units are in production and the DAC-END can start.
Information:
A. The PCB has the following data:
Material: FR4 - 1.6mm
Layers: 2 and 1
Board size: 95x110 mm
Surface finish: Immersion Gold
Copper weight: 70µm
Soldermask: Both sides - Red
Silkscreen: Legend on top
B. The price will be as followed:
On set (4PCB)
1. PCB- DAC END =$15
2. PCB- Salas Shunt For DAC=$15
3. PCB- I/V stage =$15
4. PCB- 10M45 for I/V= $10
5. Worldwide shipping: $ 5
6. paypal fee: 3,5%
A donation of $2usd to diyAudio will be done for every DAC-END pcb sold
A gift $1 for Salas contribute to diyAudio,I thank Salas very much.
Pre-Orders only at papal: quanghao168@yahoo.com.vn
Best regards to the community
Quanghao
Information:
Layers: 2 and 1
Copper weight: 70µm
On set (4PCB)
6. paypal fee: 3,5%
Quanghao
Information:
Layers: 2 and 1
Copper weight: 70µm
On set (4PCB)
6. paypal fee: 3,9%
Quanghao
I'm starting saving money for it.....
What bout all component cost? in US $ please....
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
