HiFi Database - Images, Specs, Manuals and Reviews
Under Onkyo they may have something similar. Their models had similarities. So you may find something close. Integra made by Onkyo is also on the site, but you seem to have to search for that.
I look on other onkyo amp of the same year but I found nothing similar mounted with opto-coupler.
Its not available for free but you could buy it at a few places, here is one source.
Download ONKYO A-8990 Service Manual
OK thank you it's a serious site?
if it's not coming out of protect it's either a supply fault or an output stage fault.
should be easy enough to find failed components and assess the damage without needing a schematic/manual and estimate/research replacement costs, then get documentation, non?
bonne chance...
bonne chance...
bonne chance...
He is repairing now he is coming out of protection, it was a M5218L that deconed! But now he makes me a big ploc enough strong on a channel from time to time
good thing i know the translation of "ploc" as "thump"
with replacing that inline M5218L are all associated capacitors testing good?
all the capacitors are replace, I think there is a semiconductor that kinks from time to time but must find which one! I tested all the transistor at Atlas DCA75pro it is ok .I will try to replace the other m5218L
now i see why your looking for service info it is a deeper level problem.
it still seems like cap troubles to me in most of the "PLOC" scenario's i've troubleshot the noise comes from dc levels shifting, which could be transistor break down, look for a hot one.
bonne chance mon ami!
puis ca va bien?
Yes it's good all was well the 2 M5218L who was dead ..... I replaced the LTZ-MR15 around too!
- Onkyo Grand Intégra a-8890
