Pass Aleph P 1.7 controls
Hello,
using my sacd player Lindemann 822, that has a balanced output of 4,6v/100 ohm, into the P1.7 preamp is it better theorically to use some attenuation with the internal switches and 'open' the front double gain pots or go 'straight in' without any resistance switch and 'close' the pots maybe at 9 o'clock?
Thanks,
Stefano
you didn't said what amp and speakers you are using, but with 4V6 as DAC output, what you need is not preamplifier but simply attenuator, hopefully adequately buffered
4V6 is seriously high voltage for line level .......... when 2V is practically modern standard, enough to drive most power amps to full power
Reactions: rayma
lemme see........
3.9, 60W@8R/channel
+26.6 gain, which is ~21.4V/V
60W@8R means 21.9Vrms
divided with 21.4, results in roughly 1Vrms of input voltage for full blast
meaning - your DAC itself is more than 4.9 times capable to make SA3.9 reaching full power
so, finding/buying/stealing/building decent preamp without gain (selector with buffered attenuator) is much better solution
take Iron Pre (bal) from Store, build it without output autoformer and enjoy
Reactions: rayma
