Nothing worse than a HD failure 🙁
Still, i fixed it in the end, it was the gain pot.
I've replaced it and it's now working on both channels. It does seem like a well made unit. 🙂
If I come across one of those drives I will let you know. 🙂
Hi!
Thanks MikeHunt79 I, only need PCB for HD.
I need to back up files from HD & I'll return PCB!
Why NOT!
In past everybody who needed SCH for Phonic product I've sent it.
Regads zeoN_Rider
Why NOT!
Regads zeoN_Rider
Hello, please can someone help me, I have a phonic 2500 amp that plays perfectly from channel 1 but channel 2 is stuck at full volume regardless of the position of the volume pot on the front. I've tested the internal fuses and they are all ok and it all lights up.
Please can someone tell me if its likely i need a new volume pot for channel 2 and if i do, what spec it needs to be, part number etc or a service manual that contains the info.
Thanks in advance. Al.
Hi zeonrider. Could I request you to send me copy of the schematic and/or service manual for the Phonic Max2500? I prefer a full service manual. I have one that is going into shut-down within minutes of power up. I run an electronics repair shop here in Olympia, Washington, USA and would be willing to share some of the service manuals I have with you that I have collected (NOT from this site).
Thank You!
Tim Prellwitz
admin@timilen.com
Thank You!
Tim Prellwitz
admin@timilen.com
In need of a service manual
I need a Phonic Max2500 amp repair manual. I'd prefer the manual but a master schematic might be acceptable and could possibly do the job. I have a respectable service manual and user manuals library focused on musician and power audio systems. (Fender, Peavey, Roland, Yamaha, Harmon Kardon, etc.) I'd be willing to swap with someone for the Phonic Service Manual. You can email me at admin@timilen.com if you can help.
Thanx! 😎
Thanx! 😎
Hi, in my MAX 1500 the volume pots were 5k log units. I replaced then with 10k pots as I couldn't obtain 5k pots and they seem to work ok.Hello, please can someone help me, I have a phonic 2500 amp that plays perfectly from channel 1 but channel 2 is stuck at full volume regardless of the position of the volume pot on the front. I've tested the internal fuses and they are all ok and it all lights up.
I like the Phonic XP series. I have a XP2000 for my home stereo. Just sold a XP3000 which ran a pair of 18" 1000 watt w bins to great effect. Had problems with the XP5000 which was a new design and a bit "sensitive", I tried three of them before swapping for the 3000. The 5000 is probably sorted by now but to be honest the 3000 is enough. 5000 watt amps are a bit dodgy, dirt and humidity can make that kind of power short out ie; arc across the terminals.
PHONIC XP5100 - one channel lost
Hi everybody,
I lost one channel of my Phonic 5100...I changed all transistors but again problem...I think that some smds are lost and I can't regulate the bias.
Does anybody know where I can get a pcb board for one channel of the amp?
Any help appreciated.
Thank you.
Stefano
Hi everybody,
Thank you.
Stefano
Hi there. I am about to try some upgrade to my Phonic MAX1500 to MAX2500. Could anybody tell me exact transformer voltage differences between MAX1500 and MAX2500?
As I know MAX1500 has +-65V and I think +-90V. I really need voltages values for MAX2500. Thank you.
- Phonic MAX2500 Service manual
