Maan, woow, talking about overthinking. Just chill man. Multiple voltages? Variac? Custom windings?Are you using the same voltage for all the amps?
I am in the process of ordering my transformers, started with wanting one with 24X2 + 12X2, same current rating for all four, so that I could use either 12V, 24V and 36V.
But when I analysed it, it doesn’t appear to be as cost effective as I think, for:
1) the full transformer rating will only be utilised when I use 36V x 2, when I use 12 and 24 I will only be using 1/3 or 2/3 of the rating, so if I want 600VA for 24V, I will have to spec 900VA for the transformers ==> defeating the purpose of cost savings;
2) transformers with multiple voltages output will have to be made to order, which is actually quite costly, sometimes it may be cheaper to buy another transformer.
My other alternative is to have transformer with output of 48Vx 2, I could connect the 48V in parallel, and with floating earth method I get about +- 32Vdc, or connect that 48V in series and get 64Vdc.
Do you have a cost effective way of having multiple voltages to play with different amp at different time? Without having to resort to a Variac? Which is another costly thing to pay for.
Just build power supply for F4...400VA with 2x18VAC, after rectification, filtration, and load gets you about +/_24VDC. You can power F5, M2, AlephJ, J2, AN39 and other. If you need any other voltages, build another.
Pure DIY FAB spirit.Barrier terminal strip
@audiosteve, if you haven't, read the outboard PS thread. Lots of good suggestions and approaches there.
If you meant XLR for DC power, yes, that works great.
I've been using them for a long time for MoFo monoblocks @ 2A, Zen Lite headamp, Pearl I phono, B1 pre and many others.
DC up to 48V, for higher voltages like in tube gear I go for Neutrik Speakons.
Impressive collection!Some First Watt amplifiers sans their power supplies patiently waiting their turn in circulation.
Me tooI think that is an excellent solution for outboard ps. Simplify swapping out different amps, predicated that amps are running same voltage…
Sorry thinking out loud here…. Cheapskate over here trying to think of cheap ways to have more amps… 🤣
Curious as to why transformers is in the second level, rather than right at the bottom, since it is the heaviest.Speaking of procedure, and space…
Are those Toroidy standard or audio grade transformers? How do they compare to Sedlbauer or Talema?
They're Audio-grade. No Idea how they'd compare to Sedlbauer or Talema. But all 3 have a good reputation.
They're in the second floor for space-issues, as the IEX and front-switch couldn't to be sitting "somewhere in the plates". Below, at the 1st./ground-floor is Mark's, uhm, H9KPXG "softstart".
(Yes, the amp is reversed on the desk, the cap-bank is on the top, toroids in the middle, 230V-stuff at the bottom, so the H9KPXG is mounted feets-up...)
There are a lot of amps! I am just trying to build a pair with big heatsinks and housing several amps in them, sharing the heat sinks and PSU.Some First Watt amplifiers sans their power supplies patiently waiting their turn in circulation.
Oh, i got lot more. Many in modushop cases. This is just one rack.
beautiful caseworkA Different Zen V9
After smoking my V9 circuit a couple of years ago I tried again and this time it worked so I made a decent case for it.
Newest heater in the stable. @schultzsch’s Boo OS with LUs.
This one was a long time coming. Very generous transcontinental work and support from Romania.
It took me so long to get this done that Gianluca changed the heatsink rails at Modushop in the time since I started with this amp. My heat spreaders no longer fit, so I improvised with spacers. The chassis is now is a Tie-Fighter.
I have barely enough gain with my Iron Pre to get this to normal listening level, so some gain structuring is in order. However, for now, it sounds sublime. Quick assessment is it sounds like it’s between my K1530/J201 F5 and my Scryer. VERY respectable company. I think my favorite amps list now has three entries.
Thanks again, @schultzsch !
Looking good
If the vds on the lu is set low it will sound closer to the scryer, set it higher and will sound closer to the f5.it sounds like it’s between my K1530/J201 F5 and my Scryer
- Pictures of your diy Pass amplifier
