Pins for DIP 8 adapter
Joined 2018
I bought some little SOIC to DIP pcbs to swap in a THS4032 into a DAC that has the usual DIP 8 socket.
The pcb has 8 holes as you would expect. I have some 2.54p headers that I thought fitted the bill but the pin is too thick for the socket for the op amp.
I cant seem to find on RS what I need. Any guidance?
Turned pin headers (round, about 0.5mm) are for DIP sockets (especially those with round holes).
Square pin headers (0.65mm across, 0.85mm diagonal) - Dupont style, will not normally fit IC sockets, they are the same size as IDE connector pins and frequently used for inter-board connectors.
Typical IC pins are 0.45mm x 0.25mm (about 0.5mm diagonal)
Why not cut the legs off two 1/4 watt resistors and use those to fabricate your "pins" ?
Bend one of these pieces of wire into a U-shape, where the lead-to-lead spacing is 2.54mm (0.1"). Then insert it (on the component side of the adapter PCB) into a pair of adjacent holes. Tape it down, turn the PCB over, and solder the two legs. Remove the tape and cut away the middle part of the U, removing the pin-to-pin short circuit.
Repeat a total of four times, giving you eight legs. Trim legs to 10mm length, done.
They're not especially stiff but they don't need to be. Because they are short, there's far less chance of bending them accidentally when you insert into a socket.
I did this myself when making a DIP adapter for the OPA1622 (10 pin VSON SMD package with thermal pad). Sorry for the crummy photo quality
545380d1461533256-audio-op-amp-opa1622-side_view-jpg
