Port Design Question
I have been playing with WinISD and have decided to attempt to design a speaker with a slot port. This is what I have made in SolidWorks pretty quickly. The slot is 1in x 8in with a total length of 32in measured from the centerline of the port. I included rounded corners to hopefully lower air speed.. I am asking here if this is realistic and if this works. I found a woofer that I could use to tune the enclosure to 25 Hz.
These are supposed to be decent-sized speakers. The total dimensions of the enclosure is 27x13x9.5, this is a section view to show the port path.
Do you plan to make a 2way speaker with a 6.5" or 8" woofer?
Are you sure the 25 Hz tuning works as expected?
Your driver is either a heavy membrane subwoofer and may not be best suited for a 2way. Or it is a classic midwoofer and the low tuned enclosure will not have much influence except a slight bump at 25 Hz in the falling slope.
If it's going to be a woofer assisted wideband (WAW) it probably works fine with a subwoofer, but your wideband needs a separate enclosure.
