Potential EUVL F5X designed case user distribution check
As promised details of the case GB.
If you can recall, we started to design and offer the case at the request of the forum. The initial understanding was that we should supply everything turn-key and over multiple batches as the forum would require.
Business considerations forced us to go back on our promise, and we apologised to Variac and Jason for that. But since we made the promise openly, we discussed amongst ourselves and decided to offer one batch of 25 cases for 2011. We shall review the situation again in 2012. So this one batch will be organised as a Group Buy. The forum did consider running the Group Buy, but decided it was too much work and too few will benefit, especially for the long term. That discussion delayed things somewhat.
We have then made alternative plans and organised a team that runs this as a memebers' group buy. The team is led by johnwmclean, with three regional distributors (pchw, smyslow, and johnwmclean) who will collect money, make bank transfers to us, collect the shipment from customs, and send them on to you. So please contact them directly.
Sending Conrad heat sinks to Mark Lai in Hong Kong for machining is very expensive. Surprisingly sending to the US is much cheaper. So we thought there is little point in doing that just to drill and tap a few holes. We therefore agreed to organise the heatsinks as a supplementary Group Buy. It will be limited to those who subscribed for the case, 1 pair of heatsink each, pre-drilled to suit the case only. John and the distributors have kindly agreed to do the extra work and organise this as well. John will get a set of drawings from us soon, so that he can ask for quotes, shipment costs, etc. for each continent. So you are getting Conrad sinks at cost.
As our motivation for the case was always not profit making but to facilitate the F5X build, and provide some financial support for the forum, we want this to still apply. So the cost we announce here is our actual parts cost, plus 10% (cosmetic reject rate from experience). Cost to you will, on top of that, be bank transfer charges, shipment from Mark to distributor, custom fees and taxes, individual shipment to you, etc. Do bear those extras in mind. In addition, we would like to ask you for a voluntary donation to the forum for 50 USD per case. But I leave that to you to decide whether you want to support the forum's long term existence. The second batch onwards, if any, will definitely not be "charity price". So lucky for the subscribers (and probably those on the reserve list).
The list is now frozen at 25 subscribers and 6 reserves. We'll see how many people will opt out and try to support as many as we can.
The complete set of case parts (without the Conrad heat sinks), will be offered in two options :
1) Blank case, as you would buy from any vendor, with no drilled holes at the back and the cradle for connectors, transformer mountings, etc. People who wants to use the case for single ended F5, e.g. should take this option.
2) F5X case fully finished, identical to the prototype shown, with all holes for connectors, etc pre-drilled, and internal parts to hold the regulator heatsink, PSU cap PCB holders, etc. We think it is better to let you source the regulator heatsink locally or as a Group Buy, as the Fischer sinks we used are quite heavy, and expensive to send to Hong Kong for machining and anodising. Any heatsink that will take 35W per channel and not bigger than 120x134x50mm will do, so you can also source locally. The regulator PCB which sits in the middle of the sink has a size of 30x132mm (per channel).
Both will be test assembled at the factory before being dissembled again and packed for shipment. Mark will be present personally to check for cosmetic quality as well as fit of part (using our pair of CNC drilled heat sinks as dummies).
I shall publish a BoM for each version later.
The net price (to be transferred to Mark Lai with all bank charges pre-paid) will be 320 Euros for option 1, and 360 Euros for option 2. They will both be supplied with the CNC drilled aluminium top plate, and not the laser cut stainless steel with wire mesh as posted. This alone costs 25 Euros extra, but we think it is better solution as gluing a wire mesh to a plate (by you) requires quite some skill, and we do not want you to have poor results. Both will also include all mounting screws for the case parts in 304 SST.
Estimated delivery date not before September 2011. And we would like 50% down payment upfront.
The Conrad heat sinks I estimate to be 100 Euros a pair. But there have been previous GB so you can check there as a reference.
Please confirm your subscription by adding confirmed behind your name, or delete as appropriate.
Hope the arrangements are agreeable to most if not all,
Patrick
PS PCB details will be posted at the F5X thread.
Bill of Materials :
Option 1
1x Front Plate, 6061 aluminium, fully machined, matt silver anodised
1x Front Cross Bar, 6061 Aluminium, fully machined, black anodised
1x Push Button, 304 SST
1x Cradle, folded 6063 aluminium, then machined to size, black anodised
1x Perforated Top Plate with X, 6061 aluminium, CNC milled and drilled, matt silver anodised
1x Rear Bracket, folded 6063 aluminium, then machined to size, no connector holes, black anodised
1x Rear Panel, 6061 aluminium, machined to size, no connector holes, matt silver anodised
Set of 2 Bottom Side Covers, folded 6063 aluminium, then machined to size, black anodised
Set of 4 Case Feet, 304 SST, with embedded O-rings
Set of 2 Transformer feet, 6061 aluminium, black anodised, with embeded O rings
Set of 5 Mounting angles, 6061 extruded aluminium, fully machined, black anodised
2x Handles 304 SST
Set of mounting screws for the above, 304 SST.
Option 2
All of the above plus :
Rear Bracket and Rear Panel fully drilled for connectors as per Prototype
6x Support Pillar for regulator heat sinks.
Set of 3 Cross Beams for regulator heat sinks, 6061 Aluminium, fully machined, matt silver anodised.
Set of 4 Delrin Holders for PSU Cap Board PCBs, fully machined.
Not included :
1 Pair Conrad Heat Sinks MF35-151, drilled and tapped to our drawing
Patrick
pchw, USA, 1
Horio, USA, 1
flg, USA, 1
Woody1911a1 USA , 1 (pending pics and specs)
Kannan_s, USA 1
Alazira USA 1
triode4 ,USA,1 (pending pics and specs)
NYCone, USA, 1
Necplusultra Canada , 1 (pending pics and specs)
Westley, USA, 1
Subtotal American Continent 10
All 10 accounted for
qusp, Australia, 1 (tentative till details)
Confirmed Option 2 johnwmclean, Australia, 1
leejh, Korea, 1 (tentative till details)
pmchoong, Kuala Lumpur, 1
Nikon 1975, Japan, 1
Subtotal Asia 5
All 5 accounted for
smyslow, Austria, 1
ramallo, Spain, 1 (pending pics and specs)
heinz1, Germany, 1
CeeVee, Portugal, 1 (tentative till details)
hesener, Germany 1
APK, UK 1 (tentative till details)
Chalkandtalk, UK 1 (tentative till details)
Studley UK 1
Mravinsky, Spain 1 (tentative till details)
walter burkhard, Germany 1
Subtotal Europe 10
Reserve list (in case of opt out's) :
AndrewT, UK, 1
Ferrari, Netherlands 1
dr.strangelove3 1
JBdV,Netherlands,1
scranton, USA, 1
Shaman, GR, 1
CanAm Man, USA, 1
who Is distributor for Europe - at which country and what would be shipping and custom tax for 1 pcs of case from Mark at China or Honk Kong to distributor
the volume and weight of parts Is not cheap to transport
what Is expected custom value for 1 case - or parts would be send as gift
pchw, USA, 1
Horio, USA, 1
flg, USA, 1
Kannan_s, USA 1
Alazira USA 1
NYCone, USA, 1
Westley, USA, 1
Subtotal Asia 5
All 5 accounted for
smyslow, Austria, 1
heinz1, Germany, 1
hesener, Germany 1
Studley UK 1
Confirmed Option 2Mravinsky, Spain 1 Confirmed Option 2
Subtotal Europe 10
AndrewT, UK, 1
dr.strangelove3 1
JBdV,Netherlands,1
scranton, USA, 1
Shaman, GR, 1
CanAm Man, USA, 1
pchw, USA
Horio, USA
flg, USA
Woody1911a1 USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Studley UK
Confirmed Option 2 Mravinsky, Spain
Subtotal Europe 10
AndrewT, UK
dr.strangelove3; Netherlands
JBdV,Netherlands
scranton, USA
Shaman, GR
CanAm Man, USA
Patrick
pchw, USA
Horio, USA
flg, USA
Woody1911a1 USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Studley UK - confirmed option 2
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
scranton, USA
Shaman, GR
CanAm Man, USA
I'll answer these questions for the benefit of all :
> who are the regional distributors
As already stated, pchw for North America, symslow for Europe, johnwmclean for Asia.
The cheapest is to ship them in bulk (10 cases together) rather than individually.
We shall get quotes for a few forwarders and then you can decide which one to take.
Worst case is individual parcel by post which will be around 40 Euros per case by surface mail.
Hongkong Post - Postage Rates
But we should come under that.
For reference the 2x SumR transformers for the prototype cost us 124 USD to ship surface mail from Canada to Hong Kong.
> what would be custom tax for 1 pcs of case
Whatever is legally required. I think Europe minimum 19% VAT.
Please contact the regional distributors for details.
No. No customs officer would believe they are gifts.
Patrick
pchw, USA
Horio, USA - Confirmed Option 2
flg, USA
Woody1911a1 USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
qusp, Australia
johnwmclean, Australia - Confirmed Option 2
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Studley UK - Confirmed option 2
Mravinsky, Spain - Confirmed Option 2
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
scranton, USA
Shaman, GR
CanAm Man, USA
wow , i just did the math and while it looks fantastic , i personally cannot justify that kind of expense at this time .
case option 2 = $520 usd plus shipping
conrad heatsinks = $170 shipped , quote was on 2-27-11
that puts the cost of this case to us americans at over $700 usd .
that doesn't mean that i won't be building this amp .
please remove my name from the list and offer my case to the next in line .
cheers , Woody
pchw, USA
flg, USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
scranton, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
Shaman, GR
CanAm Man, USA
pchw, USA
flg, USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
scranton, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
Shaman, GR
CanAm Man, USA -- Confirmed Option 2
Nice class A amplifier cases are unfortunately expensive.
http://www.diyaudio.com/forums/pass-labs/172770-balanced-f5-question-12.html#post2365652
My initial estimates were around 500 Euros including heatsinks but without shipment.
My own cases (machined myself) cost much more than that, material alone.
Maybe you can contact Dave to see if he can offer you something less costly :
http://www.diyaudio.com/forums/solid-state/172852-new-amplifier-chassis.html
Patrick
pchw, USA
flg, USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
scranton, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
smyslow, Austria - Confirmed Option 2
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
Shaman, GR
pchw, USA - Confirmed Option 2
flg, USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
scranton, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands
Shaman, GR
flg, USA
Kannan_s, USA
Alazira USA
triode4 ,USA
NYCone, USA
Necplusultra Canada
Westley, USA
scranton, USA
qusp, Australia
leejh, Korea
Nikon 1975, Japan
Subtotal Asia 5
ramallo, Spain
heinz1, Germany
CeeVee, Portugal
hesener, Germany
APK, UK
Chalkandtalk, UK
Subtotal Europe 10
AndrewT, UK
JBdV,Netherlands - Confirmed Option 2
Shaman, GR
CanAm Man, USA - Confirmed Option 2
