new attenuator from elma
crazy concept. Elma switch (hall based) with 6 bit relay attenuator......
http://www.elma.com/en/products/rot...lutions/product-pages/x4-audio-series-detail/
IMHO from elma (swiss ?) we can expect top quality....
gebi
gebi
Good pictures - please load up here, because photobucket delete them anywhere.Alps, attenuator + Balance pot from Sony TA-E88B.
Regards zeoN_Rider
Now a question: currently versions from Alps (RH2701, RK27112 etc.) use at the shaft for fixing not a part in the kind as to see in the first picture (btw - what is the naming therefore?).
Instead this the part looks like in the attached image (see also about
Alps Potentiometer
and go to the third picture)
and thus I must destroy and replace it through a new part in cases for disassembly.
From where I can order this part to put on the shaft before assembly, what is the english naming and which tool therefore I should use?
Thanks for advices.
Which 3rd?
Have a look to the attachment - that is the picture.Which 3rd?
The asked part has follow naming in english:
Starlock retaining washer
Now I am looking for a tool for removal it in the right size for the mentioned Alps model.
I. e. a starlock washer removal tool.
This site is very interesting
https://starlocks.wordpress.com/category/uncategorized/page/7/
any news?Have a look to the attachment - that is the picture.
Uncategorized | Starlocks Blog | Page 7
Under ebay I discover this offer:
New VISHAY SMD Resistor Relay R2R Dual Channel Six Foot Potentiometer 5K/10K/50K | eBay
Where can I download a datasheet of these pontentiometer from Vishay?
This thread don't provide this:
interesting pot !!!
Thank you for advices.
Is it Vishay? It says unbranded in the description, also look here: interesting pot !!!
Switchable Attenuators (Rotary Switch)[/U][/B]
Shallco- Precision Rotary Switch Products
Shallco - Attenuators
Elma Electronic Americas English Products: Rotary Switches, Audio Switches, Audio Switch Series C - w/SMD Resistors
DACT audio attenuators (ELMA Rotary switch with finished resistor network)
Compare Attenuator Types (ELMA Rotary switch with finished resistor network)
palazzo switches
Rotary switches Index
Seiden (inside by Luxman)
SEIDEN Products
http://www.audiodesign.co.jp/image/SeidenRotarySW400.jpg
http://www.audiodesign.co.jp/image/HAS-SGP-Terminal400.jpg
http://www.audiodesign.co.jp/image/HAS-SW400.jpg
http://www.audiodesign.co.jp/image/DCP-Inside640.jpg
Jancocorp. Janco switches
http_www_jancocorp_com/products/catalog(death)
Which brands do you prefer?
This brands are good available:
ELMA
http://www.elma.com/en/products/rot...tching-products/product-pages/type-04-detail/
Type 72 (formerly Painton/Plessey 72)
https://www.blore-ed.com/type-72
SEIDEN
http://solidgreen.co.jp/products/pdf/SEIDEN.pdf
http://www.soniccraft.com/index.php/rotary-switch-seiden-c-338_342_375
https://www.ebay.com/itm/1pc-Japan-...-Audio-Attenuator-Potentiometer-/221280756262
Hard to find are this brands/models:
COLE-SWITCHES
http://www.cole-switches.com/products/openframe.html
http://www.cole-switches.com/pdfs/op_frame.pdf
http://www.condoraudio.com/
http://www.condoraudio.com/wp-conte...am-Alpha9-Amplifier-Upgrade-Switch-Repair.pdf (page 4)
Janco Corp.
http://www.esterline.com/controlandcommunication/Mason/JancoRotaryProducts/RotarySeriesAForm.aspx
Shallco
http://www.shallco.com/portals/0/industrial/additional/Open-Frame.pdf
http://www.percyaudio.com/Catalog.pdf (page 13)
Which of them are the best?
Shallco. By a decent margin.
Please let me know the manufacturer for download datasheet of this rotary switch - thank you.I did try with alps and noble and one the 23 step attenuator from Korea is better. check these pictures of it. They are very well build and accurate and the best is the price $ 25 each approximate.
@merlin el mago
Look, this is your point I'm asking about. I don't know why you would make one and then refuse to explain it when asked.
To me, "the best" is in reference to the resultant sound quality, and I'm not familiar with any "sound quality" metrics that you can find in a data sheet. Maybe you could specify what to look for?
Update post #1
I. not switchable Attenuators (Potentiometers)
General hints:
Audio-Potis, Kontra Leitplastik gegen Steped Version
Precision Electronics Corporation
Precision Electronics Corporation: Potentiometers
Penny & Giles RF15/PGFX3000
http://www.controldevices.net/P&G/PennyAndGilesPDF/RF15_datasheet_sept11(EN).pdf
http://www.controldevices.net/P&G/PennyAndGilesPDF/PGFX3000.pdf
Alps RK501
http://www.alps.com/prod/info/C/PDF/Potentiometer/MetalShaft/RK501/RK501.PDF
Megatron OMCP30/MP(A)21/MUP/MCP50
http://www.universalimport.se/MegatronOMCP30.pdf
https://www.megatron.de/produkte/drehpotentiometer/drehpotentiometer-mp21.html
https://www.megatron.de/produkte/drehpotentiometer/drehpotentiometer-mpa21.html
https://www.megatron.de/produkte/dr...ometer/mehrwendel-drahtpotentiometer-smt.html
https://www.megatron.de/produkte/leitplastik-potentiometer/leitplastik-potentiometer-mcp50.html
Altmann
https://www.potentiometer.de/index.php/produkte-de/1gang-de
https://www.potentiometer.de/index.php/produkte-de/pp-de
TKD
http://www.tkd-corp.com/products/pot/potentiometer.html
http://img33.imageshack.us/img33/2539/p1000201wq.jpg
EIZZ
http://www.goodcomponent.com/produc...otentiometer-hifi-audio-diy-gdpr001-1252.html
http://eizz.cn/en-us/z14.html
NOBLE XVB93/XV09411N10FF-0B5K (ultra long live)
https://www.noble-j.co.jp/en/products/download/catalog/potentiometer01/XVB93/potentiometer_XVB93.pdf
https://www.noble-j.co.jp/en/produc...meter02/XV09914/potentiometer_rotary_type.pdf
https://www.hificollective.co.uk/potentiometers/noble-potentiometers.html (NOS)
https://www.head-fi.org/threads/im-seeking-for-noble-potentiometer-please-help.443825/ (NOS)
https://www.pikeamp.com/products/noble-dual-stacked-50k-potentiometer (NOS)
Panasonic ACS7011-B
https://de.aliexpress.com/item/Orig...x-potentiometer-30MMF-handle/32614154786.html
http://www.sanyelectronics.com/dual...100k-30mmf-shank-length-acs7011-b_p25423.html
Potentiometer replacement for Sony TA FA 777 ES (NOS)
Audio Note
http://audionote.co.uk/comp/atten.shtml
TOCOS (long life)
http://www.tocos-j.co.jp/e/catalog/new/new20.html
http://www.tocos-j.co.jp/e/catalog/data/electric-wheelchair-selection.pdf
https://www.hificollective.co.uk/potentiometers/tocos-cosmos-stereo.html
Allen Bradley (only NOS)
https://www.hificollective.co.uk/potentiometers/allen-bradley-potentiometers.html
Vishay (seems to be actually a rotary switch in a potentiometer outline)
https://www.ebay.co.uk/itm/New-VISH...472431?hash=item3f882b342f:g:iTQAAOSww1dZzoCB
State Electronics - The Potentiometer Specialists®
http://www.potentiometers.com/index.cfm
General hints:
Alps RK501
Altmann
TKD
EIZZ
Panasonic ACS7011-B
Audio Note
TOCOS (long life)
update post #1/#2
II. Switchable/Stepped Attenuators
(Rotary switches - both for volume control and input selectors)
General Considerations
stepped attenuator rotary switch mechanisms | Head-Fi.org
Cleaning DACT Stepped Attenuator – Jimmy's Junkyard
Stepped attenuation vs. volume pots... are they that different? | Head-Fi.org
ITI AUDIO MES-432C/9 | AudioTechnology Magazine
Top Quality versions
Ultra High Quality Version (very special open frame military grade ultra durable switch with carbon film resistors, unknown brand)
Audiobits HIFI Distributor: Stepped Attenuator
DAVEN SPEC 2597/CP-350 (Vintage)
https://www.worthpoint.com/worthopedia/vintage-daven-attenuator-pot-spec-118614534
https://www.worthpoint.com/worthopedia/daven-attenuator-nos-type-cp-350-ser-136368539
https://www.surplussales.com/Equipment/AudioAttenuator.html
http://www.jamesfei.com/pictures/pictures-recording-tech/pictures-recording-tech.html
http://windypapa.exblog.jp/18648298/
Marchand Electronics Inc. model "AT46" (large open frame version, unknown brand)
http://www.marchandelec.com/att.html
Amtrans
http://www.amtrans.co.jp/ovscust/UATS_M_e.pdf
http://www.amtrans.co.jp/ovscust/ATLSS_e.pdf
https://www.dhtrob.com/impressies/amtrans_sats.php
http://www.partsconnexion.com/controls_rotary_amtrans.html
http://www.acoustic-dimension.com/amtrans/Amtrans-SAT-attenuators-datasheet.pdf
Grayhill
http://www.grayhill.com/products/rotary-switches/
http://www.grayhill.com/assets/1/7/Rotary_53,57,59.pdf
ELMA/Goldpoint/DACT
https://www.elma.com/en/products/ro...tching-products/product-pages/type-04-detail/
http://www.goldpt.com/
ALPS RK50 - Is this the best volume pot in the world? (advices in post #4)
Which is the best potentiometer to buy? (advices in post #11)
http://www.dact.com/html/input_selectors.html
http://www.dact.com/html/attenuators.html
http://www.diyaudio.vn/dad_attenuators.htm
SEIDEN
Blore Edwards Limited
https://www.blore-ed.com/type-px
https://www.blore-ed.com/rotaryswitches
TKD
http://www.tkd-corp.com/products/rotaryswitch/rotaryswitch.html#rr30g
https://www.hificollective.co.uk/switches/TKD-2-pole-6-way-selector-switch.html
https://hfc-fs.s3-eu-west-1.amazonaws.com/s3fs-public/tkd_2r6a_datasheet_0.pdf
http://www.hkbush.com/tkd-2p65cs-40-steps-stereo-attenuator.html
Acoustic Dimension (large open frame version, actually brand unknown)
https://www.tnt-audio.com/accessories/stepped_attn_e.html
JANCO (now Esterline)
http://www.esterline.com/Portals/6/Products/Mason/Docs/ECCS_Janco_Series_A_rotary_switches.pdf
http://www.esterline.com/controlandcommunication/Mason/JancoRotaryProducts/RotarySwitchSeriesM.aspx
Shallco Open Frame Rotary Switches
https://web.archive.org/web/20110610082435/http://www.shallco.com/attenuators.html
http://www.shallco.com/IndustrialSwitchProducts/AdditionalSwitchProducts.aspx
Electroswitch
http://www.electro-nc.com/rotaryus/m5.pdf
http://www.electro-nc.com/rotaryus/m4.pdf
COLE Instr. Corp.
http://www.cole-switches.com/pdfs/s3600.pdf
http://www.cole-switches.com/pdfs/s3900.pdf
http://www.electro-nc.com/rotaryus/e_sel.pdf
mti - multi-tech-industries (Radio Switch Corporation)
http://www.multi-tech-industries.com/aboutus.html
http://www.multi-tech-industries.com/rswitches.html
http://www.multi-tech-industries.com/test-switches.html
Economy, but good quality
Palazzo
http://www.commutatori-palazzo.it/inglese/commutatori/indice.htm
ALPS 2 pole 6 way, shorting selector switch, SRRM series + SRRN series - e. g. SRRM262400
http://www.alps.com/prod/info/E/HTML/Switch/Rotary/SRRM/SRRM_list.html
http://www.alps.com/prod/info/E/HTML/Switch/Rotary/SRRN/SRRN_list.html
http://www.alps.com/prod/info/E/HTML/Switch/Rotary/SRRM/SRRM262400.html
https://docs-emea.rs-online.com/webdocs/1531/0900766b81531899.pdf
sourcingmap®, dealmux, uXcell, ConneX and similar, but actually unknown manufacturer
https://www.parts-express.com/kxm-2...tube-audio-guitar-amplifier-or-radio--023-216
https://www.jlmaudio.com/shop/gain-switch-2-x-12-position.html
http://www.altronics.com.au/p/s3015-12-position-90-deg-pcb-mount-rotary-switch/
http://hongyu.manufacturer.globalso...igital-changeover-precision-rotary-switch.htm
http://glass-ware.stores.yahoo.net/atandsise.html
https://www.reichelt.de/Drehschalte...ndex.html?ACTION=3&GROUPID=7594&ARTICLE=15295
https://www.musikding.de/Rotary-switch-4P3T-open
https://www.sparkfun.com/products/13253
http://www.partsconnexion.com/controls_rotary_connex.html
Connex Switches
https://www.amazon.co.uk/sourcingmap®-Split-Positions-Rotary-Switch/dp/B008MJWTY6
https://www.amazon.co.uk/sourcingmap®-Channel-Rotary-Switch-Selector/dp/B00N42CF40
https://www.amazon.de/DealMux-Drehwahlschalter-Pole-Positionen-Deck/dp/B016FFAFW6
https://www.amazon.com/Electronic-Machine-Position-Rotary-Switch/dp/B00K81OD2C
https://www.amazon.com/uxcell-Channael-Rotary-Switch-Position/dp/B00DUYQPBG
http://www.uxcell.com/panel-pcb-wiring-rotary-switch-pole-positions-deck-220v-p-243782.html
very bad quality/very short lifetime
https://www.lorlin.co.uk/catalogue/gck/
https://www.lorlin.co.uk/catalogue/cks/
https://www.elma.com/en/products/ro...tching-products/product-pages/type-01-detail/
https://www.musikding.de/Rotary-switch-2P3T
https://www.musikding.de/Print-rotary-switch-1P8T
http://hongyu.manufacturer.globalso...howroom/3000000157626/12652/Rotary-switch.htm
very bad Alps rotary switches used in top class pre- and integrated amplifiers
http://www.electronicsurplus.com/alps-160595-3-switch-rotary-contacts-4-pole-5-position
Alps Rotary Switch Dropout Issues for Input Select (e.g. Onkyo, Yamaha, Creek)
http://www.amprepairservices.co.uk/repair-blog/4559566775
Amtrans
Grayhill
ELMA/Goldpoint/DACT
SEIDEN
TKD
Electroswitch
COLE Instr. Corp.
Palazzo
Connex Switches
Here's another of the TA-E88B attenuator (took this around 9-10 yrs back - there are others of its guts in the folder - it has all kinds of innovations, such as bulk film resistors etc. No expense spared. THD spec met Sony's paper spec to the 1/100 point. Marred by ripple...got rid of it before I figured out whether it was the pair of EI transformers or regulation that caused said ripple)
![LevelAttenuator-crop.jpg](https://oi646.photobucket.com/albums/uu186/Justin-G-2009/LevelAttenuator-crop.jpg)
This Sony/ALPS attenuator is a masterpiece.
I have just installed one piece of the ubiquitous Chinese rotary switch that can be buy everywhere on the Internet to replace a broken stepped ladder volume control.
I have two type of this kind of Chinese item - one I have bought through an E-Bay vendor, and the other from this site : Bargain Ex-military Attenuators 23-Position, 2 Channel (Stereo) – DIY Hifi Supply
Though the "ex-military" claim is obviously ********, I'd like to point out that, apart from having gold plated leads (I have not yet opened one piece to see if it's also gold plated on the inside), the second variation is softer to turn, as it requires less force. As such, this variant is more comfortable to use as a volume control, especially with a not very wide button.
I also like to share a very convenient online calculator that automatically generates a spreadsheet of the resistor values for up to 24 positions ladder attenuator : Stepped Attenuator Resistor String Calculator - Neville Roberts
Please also take note that the production of Palazzo rotary switches has been transferred to G. Milani commutatori : Catalogo Commutatori G.milani.
I still looking for that.Have a look to the attachment - that is the picture.
- Design & Build
- Parts
- Potentiometer Overview - Alps, Penny+Giles, TKD and Vishay and more, what's your fav?
