A throwback to when I was 18 YO.
I'm finally going to use the Kicker EX124 drivers in a biggish box and a pair of SB mid-bass I bought off rabbitz; pre-Covid.
SB17MFC35-8
But I have a small problem here as my copy of Jeff Bagbys Passive XO and his Box Modeller no longer work.
Might take me a while tho as I have to clean up the shed first.
I read Jeffs posts [ RIP and sorely missed] about his Universal sub crossover and thinking that as I like to keep things as simple as possible I'd go with a first order electrical on the woofer as low as practicable.
But looking though my stash the only large value inductors I have are cheap laminate cored from Jaycar @ 9mH / 19AWG and a DCR of 1.9Ohms. I usually buy in pairs but I seem to have only one 5.6mH inductor there and that value was what I was going to use.
So I'm now wondering if I should make a true 3-Way crossing around 250/300Hz or simply going with a 2.5Way using a wide baffle and setting the woofer at the baffle step -3dB.Because I want a particular sound for Hard Rock I'll be using the venerable Vifa aluminium dome D26 tweeter and crossing somewhere around 2500/3000Hz.
I will be playing LOUD most of the time, these may live in the shed or be gifted to one of my kids later on.
Thoughts and prayers?
SB17MFC35-8
Its published specs would make a nice BP6 for loud, so no low pass, just damp its upper harmonics.
You must've been 18 a long time ago, Kicker dont even list specs for the EX12-4 is that an early 90's sub?
Cant even find one on a search, sure its not a C series
EX was a driver sold only in Singapore and Australia. Pretty much the same as the CX but slightly higher Fs and yes very early 90s.
I got a couple of NOS really cheaply
You know what they say; "If you can remember the 60s you weren't really there"
I was going to put them in a 35 litre sealed box [ Qb 1.1] with a large high pass capacitor in series; the same as I did for the EX154 I still have and use for parties.
A little on the high side same as for vented, so tuned a little lower.Isn't a Qts of 0.478 a bit high for a 6th order BP box?
That said, just realized I have the ES specs and worse was looking at the 154, so @ 2:33 am I wasn't as alert as I thought I was 🙁, but I've done up to 0.5 Qt BP6 that worked well once tuned empirically and vents critically damped.
Have you recently updated to a newer version of Excel? PCD has different versions for different Excel.But I have a small problem here as my copy of Jeff Bagbys Passive XO and his Box Modeller no longer work.
No rabbitz I'm still on version 7 on W10.
For some reason all the macros in Excell have stopped working, not just PCD.
OK I just did that and now I get a header that says ( Read Only) I was stilling learning on that program too.Try reinstalling Excel.
Also it keeps asking me for a password and I've never password protected the program or any of the files I saved
Its got macros embedded so some of your windows/Excel settings may be preventing them from running properly.
WinPCD is a windows version of Jeff's PCD that does not run in Excel. I think it runs in Windows.Net but I don't really know what that means.
https://www.speakerdesign.net/WinPCD/
- Pre-planning stage New big 3-way
