Preamp for Power Follower 99
Luke said:
voltage seems kinda high for 100 W, is it +/- 40V, or are you dissipating 800watts per channel:bigeyes:
How many outputs and can we see pics of this amp🙂
This scheme has "virtual ground operation" and uses +81v input, but in rezult, it have +-40.5
If there is a 800watt of power, mofets will burn :hot:
maybe you already built an preamp for power follower till now, im useing andrea's pre amp with tubes. It sounds great on midrange and high, bass is not controled well. I can sugest you to connect PF 99 to direct source, you'll get the best results that way
