Added in...
RKH - 2 x 600VA or 2 x 800VA (whatever is best for V3 monoblocks)
Justin - 2 x 600VA
gmant123 - 2 x 400VA
ra7 - 2 x 400VA
Guiness - in for a few no matter what you guys decide
Tea-bag - 1 400va@18v and 800 or 1000@24v
billyK - 800VA 24Vac x 2 - 1 unit, 400VA 24Vac x 2 - 2 units total of 3 units
wirewiggler - 1 400VA X 2 for F6,
nanchangbob - 1 x 800VA 24Vac*2
qusp - 2 x 400VA
pchw - 1 x 1000VA 24Vac*2
Russellc 1 x 1000VA 24 V x2 (For V2) may be in for 2 more.
PKI — 4x400VA@18Vx2 (universal 115/230 primary voltage)
RDK - 2 x 800VA (for "future proof" v3 mono block)
Skunark - 2x600VA or 2x800VA 24Vac for V3 mono blocks, perhaps 2 more for F6
Ryssen 1x400VA for F6
Tehrkn - 2 x 1000VA@24V
necplusultra - 2 400va@18v and 1 1000@24v
etoiledusoir-1X400va@18v
Lo_tse - 2 x 800VA
pcb121055 - 2 x 1kVA@26x2
vanofmonks - 1 x 400va@18vx2
wjh – 1 x 800VA@24Vacx2
1MOR - 2 x 800va 24V
quan-2x 400VA@45x2(230V)
petefrontiers - 2x 400VA for F5T V2
bugzbunny - 2 x 800 VA at 24V for F5T V3, 1 x 400VA at 18V for F5Clone, 1 x 400 VA for F6 Convertible (not sure about voltage for this one), 1 x 800VA (x2 45V, equiv to Antek AN8445) for the HoneyBadger Amp; prefer potted for all 5.
Mordikai 4x1000va@24v
Mordikai 2x400va@18v
luvdunhill (qty 4) 2 x 22VAC, 350-400VA <= 125mm diameter
alazira 2 x 500VA@15x2
SRMcGee - 1 x 800va @ 24VAC, 1 x 800va @ 32VAC and 2 x 1000va @ 32VAC
BDP (qty 2) 2 x 22VAC, 400VA, potted
girbim - 1 x 400va@18vx2
jcastellano - 1 x 400va@18vx2
jcon2 -(qty 2) 800VA or 1000VA @ 24va
cristianr - 1 x 800VA@24Vacx2
justadude - qty 1 - 22v @ 400va
pexo74 1 x 800VA @ 24vx2 (230v)
Flodstroem 4 x 600VA, sec @ 41Vx2 (eg. 2 matching secondary outputs) + 14Vx1@1A / 230V Prim. (Krell KSA100 II monoblocks)
1 x 600VA, Sec @ 47Vx2 (eg. 2 matching secondary outputs) + 14Vx1@1A / 230V Prim. (GB300D) all 5 pcs potted/epoxied
bk856er 1x 800VA @ 24Vx2
danielutzu - 1x800 VA at 18Vx2 (for F6); 2x800VA at 24Vx2 (for a F5T v2 balanced or for a BA3 balanced); all 3 potted, if possible
cefud - 2x800VA @ 24Vx2 (or whatever is best for V3 monoblocks)
Grimberg - 4 x 400VA@18Vx2
den054 - 1 x 400VA@25VACx2 (115/230VAC primary)
d to the g 1x 400VA w/2x18V /2x 400VA w/2x24V (a 15V 1A additional secondary would make my day)
triode4 - 2 x 1000VA 24 V x2 (For V2), 4 x 400VA 28 V x 2 ,15 V x1(for L'Amp SIT)
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Removed my name from the list. Want to build dual mono's and will wait for Antek.
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Report Post Reply With Quote
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
labjr 2 x 400VA @ 18V
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
I removed myself a couple of days ago, but I noticed that I reappeared on the list. I am removing my name again.
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
zman01 - 1 x 600VA @18Vx2 for F6 (115/230 VAC primary)
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
removed my name from the list
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Added two more...
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
bugzbunny - 2 x 800 VA at 24V for F5T V3, 1 x 400VA at 18V for F5Clone, 1 x 400 VA for F6 Convertible (not sure about voltage for this one), 1 x 800VA (x2 45V, equiv to Antek AN8445) for the HoneyBadger Amp; prefer potted for all 5. And: 2 x 500VA 2x15V Transformers for F5X (not potted)
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
d to the g 1x 400VA w/2x18V /2x 400VA w/2x24V, with additional 15V 1A secondary for L'Amp
just updated mine
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Skunark - 2x800VA@24Vx2 for F5T V3, 2x600VA@18Vx2 for F6, 2x800VA@45Vx2 for HoneyBadger, potted if possible
Lo_tse - 2 x 800VA
I've updated my list and noticed that D to the G left out Bugzbunny update's, which should be fixed above, but probably good to review again.
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
David A.M. 1 x 400VA@20Vx2 or as close as possible. Thanks.
Justin - 2 x 600VA
ra7 - 2 x 400VA
qusp - 2 x 400VA
Lo_tse - 2 x 800VA
Here ya go fellas. PLease check entry as well as listing the secondary voltages you want. Cell may be too small as is, but we will adjust. Hopefully the order is large enough that they will accommodate all the request, but some may have a decision to make if they want a to maintain discount. We will have to see. Lets get it wrapped up so we can finalize pricing.
https://docs.google.com/spreadsheet/ccc?key=0Av3k36EKupGAdDZmLXJfcDl5MkFVVEFDV2ZoX1Z3Vmc&usp=sharing
I'm curious how the discount will work? Will it be on the grand total, each VA size or each identical VA size and voltage combination?
I may be interested in ordering a couple larger ones for future projects that aren't even conceived yet because the price would be basically the same as I paid for a Plitron 400VA Group buy years ago.
- Group Buys
- Primrose(SumR Audio) Toroid GB
