Yes.
Sorry I should have specified I was looking for a supplier of lighting louvers or eggcrate louvers like the ones described previously. Grill cloth will not suffice for me.
use carbon fiber
Carbon Fiber Speaker Grilles
orsche Parts & Porsche Accessories - Wholesale Porsche Parts & Tequipment
Not cheap however really strong and will typically be acoustically transparent in the audio range you are concerned with.
Google works for lighting louvers too.
Ahhhh... sarcasm, the crutch of the weak and bitter. Good stuff. I was referring to the poster about finding it in smaller batches than commercially available... shame I should have to explain that to you. Troll on.
Carbon Fiber Speaker Grillesorsche Parts & Porsche Accessories - Wholesale Porsche Parts & Tequipment
Beautiful but just a bit out of my range for grills... thanks though.
We're talking of subwoofers here, aren't we?
Come on, what kind of discussion is that? Does a speaker grille degrade subwoofer performance?
As long as the wavelength is much greater than diameter and length of those holes, such a grille forms a lowpass in front of the speaker. Exactly like a bass reflex port. Now calculate the cutoff frequency of such a grille: it will be somewhere in the high kHz range.
So, don't even think about it. Just place that grille in fron of your sub. It doesn't matter.
Expanded and perforated metal
This may not be the cheapest place to shop, but you could at least window shop and see what exists.
McMaster-Carr
I buy so much hardware and materials from Mc Master that I have an account.
One click shopping just like Amazon, and next day delivery.
Dave
McMaster-Carr
Dave
I'm doing something different. I'm recessing a sound bar into a fireplace mantle. I can use white grille cloth or a metal grill. I never thought of how some of these metal grills can reduce the amount of sound coming out. SO for a sound bar that I'm recessing, I guess I should go with the grill "cloth", correct?Reliable Hardware quantifies how acoustically open their various flat stock is. The more open to air flow a grill is, the less it reflects output back at the cone, and the lighter it will be for its type. I would never recommend anything less than 50% open. expanded diamond cut - 63% open http://www.reliablehardware.com/images/products/detail/4023F_4_final_B.jpg perforated 5/32" round hole - 62.4% open http://www.reliablehardware.com/images/products/detail/3163_2_final_B.jpg and in distant third: perforated 3/8" square hole - 56.2% open http://www.reliablehardware.com/images/products/detail/3725_final_B.jpg After doing a lot of web crawling these seem to be the way to go for full-coverage metal jackets. My preference used to be the expanded diamond cut, but the 5/32 round hole grill has taken its place. Downsides to Reliable? Minimum order there is $25, and shipping for only one grill is rather high. So you may want to order something else there too
If you don't want reflected high frequency sound from a metal grill, use acoustically transparent cloth of whatever color you feel fits your fireplace mantle.I'm doing something different. I'm recessing a sound bar into a fireplace mantle. I can use white grille cloth or a metal grill. I never thought of how some of these metal grills can reduce the amount of sound coming out. SO for a sound bar that I'm recessing, I guess I should go with the grill "cloth", correct?
I'd think the "issues" with grilles / and more particularly their mount frames, would be related to frequency - even at the top end of the operating range described in the first post ( i.e 1200 Hz - wavelength just under 12") I'd imagine that the supposed "artifacts and distortions" created by the standard 60-65% open mesh grilles would be less of a pain than having to repair / replace damaged cones.
In the upper mids and top end, ( say 3000Hz and up) yes the frames and thicker metal mesh / perfed styles would become a significant fraction of the wavelength and have audible and no doubt measurable effects, but with careful design of fabric grilles for drivers operating at those frequencies, much of those "evils" could be mitigated to the satisfaction of all but the most obsessive-compulsive of golden eared audio-nervosa -philes. Thankfully my membership in that club expired years ago due to ennui and middle aged hearing loss / tinnitus
But you're talking woofers, and seriously, I really don't think it's that much of an issue. I'd rather convince myself that the drivers are reasonably protected than worried about what be wrong that I can't quite ascertain. If you read enough on the internet, there'll always be something wrong, and you'll never trust your own ears.
In post #29 Jason is talking about a "sound bar", a small "full range" speaker, not a woofer.But you're talking woofers, and seriously, I really don't think it's that much of an issue.
Carbon fibre?
Are you sure the grille itself is carbon fiber - I suspect the grille is regular metal and the bits that look like carbon fiber....
...are carbon fiber.
Regards, Ben
Regards, Ben
Hmmm...May give this stuff a try.
Crown Bolt, 24 in. x 3/4 in. x 24 in. Metal Plain Expanded Sheet, 45840 at The Home Depot - Tablet
If they have it at my local store I'll pick it up and let you guys know how it does...I have four TH's in need of grills!
Chicken wire is super cheap, strong, and hides well under cabinet cloth material.
Home Depot carries an apparently fancier version called Poultry Fence, for trying to keep your chickens within the limits of your gated community:
Tenax 3 ft. x 25 ft. Black Poultry Fence-206866 at The Home Depot
Steel chicken wire bends pretty easily, once bent inward can tear up the cone.Chicken wire is super cheap, strong, and hides well under cabinet cloth material.
The Poultry Fence is made of plastic and is flexible like fabric grill cloth.
True, but how I think we are talking about two different kinds of force here. Some people are trying to keep toddlers from poking fingers through, and some are apparently trying to design custom enclosures to keep moshers from hurting the cone. You gotta design to your market...
Interesting detail about the Poultry Fence though, I didn't look at the link long enough to see that.
Regards, Ben
I'm pretty sure your right. It would have to be drilled out, not cost feasible. I subjected 2 mm carbon fiber to a great deal of force and didn't break it. It did cause some minor veining but all in all remained intact and structurally sound. I'm sure part of the speakers will be safe.
Gotta love the hi Fi crowd
- Subwoofers
- Quantifying metal grill effect on sound?
