Hi there. I recently purchased a used Audio Technica AT-1100 MK III tonearm. It has the paddle and bath type of damping at the vertical pivot. Does anyone have any experience with which oil to use there? The paddle and plastic are plastic, so the oil has to be compatible with plastic. Thanks!
I don't know about the required viscosity, but pure silicone oil is safe to use with plastic.
That's a start anyway!
Apparently, the KAB damping trough uses 60,000 cst fluid, so that's probably a good number to start with. It's cheap to buy if you want a thicker fluid.
jeff
jeff
The Audio Technica manual just says silicone oil (well actually it says "silicon", doh!).
Definitely do not use any hydrocarbon product on plastic unless you are certain its compatible. Many plastics dissolve or soften in hydrocarbons.
There is a silicon oil used for CNC spindles, quite thick, sold by the liter.
You need a few cc.
Ask at Micro-Tools or a similar business.
Hydraulic oil (synthetic) may work, but it is thin, unless you get some 220 or 320 grade.
That is fairly safe for plastic.
This is fairly cheap:
silicone spindle oil 60000 cst
Just search for a nearby seller, I have no ties to anybody in that line of business.
You need a few cc.
Apparently a similar product is used in the production of cosmetics, so the larger packs may contain either.
Make sure when ordering, there is also a textile production grade, used when weaving...
Meanwhile, a seller here is asking almost $8 for a 100 cc pack, seems a small outlay, should be enough for several refills.
Hi, It is something you will have to just try through the grades, if you do not know the grade required. You can definitely over damp if you use to high cst silicon oil. I would start with 6000 cst & see how that works.
Cheers
Cheers
Hi, I use 50.000 cps silicone diff oil both in my AT1100 and SME III. https://www.absima.shop/RC-ACCESSOR...&SessionId=&a=catalog&t=19114&c=19206&p=19206
I regulate amount of damping with amount of oil in the tray. I'm sure a thinner/faster oil could be used, just use more or use bigger paddle. I would not go thicker. I believe I use 1 to 2 ml per bath, which lasts years before needing replacement 🙂.
Dagfinn
Dagfinn
Yes, radio controlled model shops commonly have a stand with a large range of silicone oils on offer ranging from around 500cSt to 500,000. I was surprised at the range when I bought some for my tonearm lift.
- Analogue Source
- Recommended oil for damping a tonearm?
